Gateway FPD2275W LCD Monitor Logo
Posted on Nov 07, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I get the widescreen monitor to show unstretched images?
I am an artist and we just purchased a new laptop. We hooked up a Samsung Flat SyncMaster216BW to the lap top so that I could work from a larger screen. Unfortunately it is a wide screen and we cannot figure out how to set it so that I can view normal aspect ratio images. Everything appears stretched. My photo suite program shows my images elongated to fit the screen. I just want to see normal images. Help????? Where do I go to set it for normal size images???? You know like the TV has the option to flip between wide screen and normal. Help???? Please -- I am so frustrated. Thank you, Joanne
PS the User's Guide CD that came with the monitor is warped and won't play. Where can I find a PDF of the instruction manual.
  • Gar663
    Gar663 Jan 05, 2008
    In settings for the display properties window, The only screen resolutions shown are for normal screens not wide screen. The monitor shows only stretched images which makes it very difficult to work on my MS Publisher and even Word documents. Please help.
  • JPetM Mar 28, 2008
    I have the same problem with us new screen ACER AL1916W. it is a wide screen and we cannot figure out how to set it so that I can view normal aspect ratio images. Everything appears stretched. My photo suite program shows my images elongated to fit the screen. I just want to see normal images. Help????? Where do I go to set it for normal size images????
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Apr 26, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1421
Points
I had the same problem with my new widescreen monitor... turns out the best setting (at least, for my specific monitor) was 1440 by 900 pixels. at this setting the desktop still stretches itself to fill the entire screen, but everything else is completely unstretched. (to adjust the screen resolution, right click anywhere on the desktop, then go to properties, then settings.)
Anonymous
Level 1:
  • Posted on Aug 05, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1421
Points
Sir i did buy samsung monitor and the model no.632NW,
Model Code is LS16PENSFMXTP and Type no. PE16WS
and Color is : High Glossy Blank
And the problem is Harizantal screen is not get wede please tell me what buttons , i have to use , please give reply now
Rommel Balcita
Level 3:
  • Master 749 Answers
  • Posted on Nov 10, 2007
Rommel Balcita
Master
Level 3:
Answers
749
Questions
Helped
377130
Points
2156
Right click your mouse to anywhere on your screen!
there should be a pop up window! click on left click your mouse on "properties"! the "display properties window" should come out!
click on "settings"! adjust your "screen resolution".
My Hyundai tv 74 cm The color it not show good
Nice big screen but CRTs are getting old So, if you can't set correct colors with your Hyundai it might have some serious issue with tube. Probably replacement might cost you more then a new new 27" Flat Panel. See some tutorial and info about bad color of CRT
Fix your own CRT Television Color Problem
How To Diagnose Bad CRT or LCD Monitor
http://www.electronicrepairguide.com/monitor-color-problem.html
LG M2762D 27 Inch Widescreen 1080p LCD TV Monitor Black
LG Electronics LG M2762D 27 FLATRON LCD TV widescreen 1080p FullHD HDTV...
RCA F27440 27 CRT TV
Samsung TXN 2798HF 27 Tantus CRT TV 1080i
Insignia digital picture frame troubleshooting
Try with fewer images. If it works, you may have too many images for the device. Contact the store or vendor where you purchased it.
Dell monitor blue light on no display
Hook it up to a different computer or laptop. If it still has issues then change out the cable. Add more info: has it ever worked? When was the last time it worked.
2helpful
I have a 22" Westinghouse
Change the settings on your HDMI output to 720 progressive for resolution. The tv likely cannot handle the 1080 resolution, or the tv can only use interlaced (1080i or 720i) format.
New purchase. VGA connection. First use, all was fine. Turned off, then back on, and image will not "center." Neither VGA Automatic nor the individual controls will adjust the horizontal enough...
Make sure you have your resolution set to 1680 x 1050 as this is the native supported screen size for this LCD. Also check your graphic card's overscan or manual adjustment settings. They might be manually set to offset the screen picture.
Hope this helps,
Chris
All of a sudden the image is not displayed in full widescreen mode it is now cropped at both sides. How do I restore to full widescreen image?> Thanks John Mleczko
You need to adjust the screen resolution.
Go to Control Panel - Display - Settings tab - change the Screen resolution.
Start at 1024 X 768 resolution and increase the resolution till you find a setting that suits you.
I want to purchase the 28 inch TV - however when I reviewed the literature I couldn't figure out if our sound bar (Samsung model # HW-C451) would hook up to it - we only have a fiber optic connection...
Well before I can tell you if there is an adapter available, you need to tell me what kind sound outputs are available on your tv. Please provide this info so that I can tell you whether there is an adapter available.
No sound, checked control panel, all shows the
No sound, checked control panel, it shows all sound at the max.
2 inch wide band of fuzzy lines in centre of screen...any ideas?
The monitor has blown some pixels.
If it is still in warranty it will need to be sent away. If not it is best to purchase a new monitor. The repairs will cost almost as much as a new one.
If this solution has helped you, please take the time to rate me.
Top Gateway Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
