With a chain splitter! It's a good idea to change the front and rear sprockets too so buy the lot when you're buying the chain. Loosen the tension on the chain tensioners on the rear wheel. Split the links. Remove chain. Remove and replace sprockets. Replace chain and be sure to use a chain riveter to sort out the joint. Don't be tempted to use a split link as your bike is too big and powerful for one. Adjust your chain tension checking for tight spots etc. Apply lube and enjoy!
