Rheem Richmond Encore Tankless Nat Gas Outdoor Direct Vent 6.4 GPM Logo
A
Anonymous Posted on Jul 12, 2014
Richmond Encore RMTG95DVLN no power? - Rheem Richmond Encore Tankless Nat Gas Outdoor Direct Vent 6.4 GPM
Gene Haynes
Level 3:
  • Rheem Master 5,391 Answers
  • Posted on Dec 08, 2014
Gene Haynes
Rheem Master
Level 3:
Answers
5391
Questions
0
Helped
2606598
Points
14124
Richmond encore 3kw electric water heater stuck on standby mode no hot water this is a brand new unit never used!
About the only DIY repairs available are on following link:
http://waterheatertimer.org/How-to-wire-Tankless-electric-water-heater.html
Richmond is made by Rheem. They may tell you to call installer. Or give you name of local repair technician.
Gene
Water Heater Timers Save Money
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
What can restrict water pressure in my water heater?
http://waterheatertimer.org/Low-hot-water-pressure.html
http://waterheatertimer.org/New-water-heater-making-noise.html
Repairs made in water line can clog heat traps on new water heaters.
Old plumbing can have sediment at elbows.
DIY resource links above.
Otherwise call plumber.
Gene
My richmond encore tankless model no. rmtgh95dvn has low water pressure coming through it. I checked the inlet filter and it is clean What else can it be?
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Old plumbing, and clogs can gather at elbows.
Plumbing repairs, faulty check valves etc can cause clogs.
Pressure gauge on water line can reveal if pressure drop is before or after the tankless unit.
Gene
Can Richmond tankless heater which is now LP be converted to natural gas?
If it can, then it is done with dip switch settings.
Read your product manual.
Switching types of gas, and messing with dip switches is dangerous.
LP gas burns much hotter than NG, and LP pressures are much higher than NG
Call Rheem with serial number and they might supply the information to you, but will likely tell you to call service technician... leaving you in exact same spot you are in now.
Gene
I keep getting a code 13 and no hot water after about 3 min. Vent is clear??
Undersized gas line?
Temperature set too high?
Haven't kept up with regular maintenance?
Tankless older than 5 years?
Hard water over 7 grains?
Gene
1helpful
I have a Richmond tankless water heater and it has L1 error code...can somebody help me with this?
Might be able to help. Except L1 does not show on any error code file.
Copy following link for Rheem Richmond Ecosense etc computer water heater troubleshoot resources
Are you sure the error is not IL? Delime tankless.
Or UL flashes and indicates reset.
Or CL flashes and indicates fault history is cleared.
Or error 11 combustion failure? Call for service.
Or P1? Low water pressure, clean water filter check for leaks and crossover caused by bad single-handled faucet cartridge.
I recommend calling Rheem to find local technician who is qualified to work on tankless computers. Tankless are not ordinary water heaters, and they require continual maintenance to avoid common error codes, especially as unit gets 2-3 years old, after warranty has expired.
The required maintenance and expense of repairs, and general fact that people cannot make their own repairs, make tankless computers a bad choice for heating water.
If unit is 4-5 years old, it might be best to install tank-type heater for $385 from Lowes and cut losses.
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Gene
h
Have 75 gallon gas water heater. Can I run 90 PVC off top power vent without vertical PVC first? Have Richmond unit.
1) I believe you can immediately elbow the PVC pipe.
There is a limit for how many elbows can be used between blower and termination, and limit is determined by diameter of PVC pipe.
2) Copy following link for venting resources and typical Rheem and Richmond power vent manuals, and diameter-elbow pdf from Bradford White.
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#venting
3) Richmond is Rheem. Product manual will show specifications for venting.
Product warranty is voided if installation does not follow specifications shown in manual.
Top Rheem Water Heaters Experts
Mike Cairns
Mike Cairns
Sean Wright
Sean Wright
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
