Apple iPhone 4S Logo
A
Anonymous Posted on Jul 12, 2014
Broken glas how to exchange glas
kristi tucker
Level 1:
New Friend:
Greenhorn:
A rookie expert who has answered 20 questions on their first day.
  • Contributor 68 Answers
  • Posted on Aug 13, 2014
kristi tucker
Contributor
Level 1:
New Friend:
Greenhorn:
Answers
68
Questions
0
Helped
4724
Points
68
It should be free with most iPhones warranties take to nearby apple store.
Wiring schematic for MTB217 cooper b line
I would suggest taking a closer look at the motor name plate. I am not familiar with a 120/240 three phase service. When I checked the web it shows: Voltage 115/230 (that is single phase), Max Amps 115 Volts = 19.2 Max Amps 230 Volts = 9.6 , Single Speed, Square Flange, RPM = 3450, Threaded Shaft, Frame = 48Y Used on the following models: Sta-Rite Max-E-Glas, Max-E-Glas II, Dura-Glas, Dura-Glas II, Dyna-Glas, Dyna-Max Pentair Whisperflow, Pinnacle and Anthony AR2 Series. You should also show what voltage you are connected to.
Triomp3 com
If the glas is broken then you either should get a new one if your warranty is still valid or you should google to look for local hardware repair shops. If neither of this options work I suggest you just buy a new one.
Hi, how can i replace the broken front + glas of my corby?
hello sir,
go to the nearest samsung service center and change the broken front and glass for your mobile.
just go on with your company.rhey will rep;ace the original parts for your Corby phone
have a great day.
thank you
My monitor case glas is broken is it covered of the warranty
unfortunately, no it does not cover the warranty. The broken monitor glass was an accident caused by you, so you will be the one to bear the consequence.
The warranty is void in this case. Warranty only covers factory problems.
I hope this is clear now. So you can go ahead and replace the broken glass.
Good luck.
My nokia c7 display glass has been broken. how much will it cost
my c7 GLASSS IS BROKEN AND WATS I WILL DO HELP ME AND I WANT NEW GLAS
Nov 26, 2010 • Cell Phones
Is it possible to fix the view screen if just the glass (not the ldc) is broken? Fuji FinePix Z5fd
There is a plastic cover over the LCD. Is only the cover broken? The plastic cover is easily replaceable.
But there is also a sheet of glas over the LCD. This is a part of the LCD assy and cannot be replaced without replacing the entire LCD.
Outer glas of the dor broken its a QA make built
I will give you summary instructions on how to repair the door outer glass on a built in kitchen.
Prepare a space on a table, where to work on the door. Cover the taple with newspaper.
Remove the door. On some model you may just need to lift and pull, on others you need to free the hinges, usually undoing few screws.
Put the door on the table. Remove fragments of splintered glass if the glass is falling apart, otherwise leave it all in one piece.
On the table remove the set of screws that are holding the external frame and glass.
Remove external glass and replace it. You can use pliers and a cloth if needed.
Do operations in revers order to refit new glass.
You can find parts here:
Appliance Parts -Research, Repair & Replace.
Oct 14, 2009 • Ovens
Broken glass sony nv-u53
an expensive repair, might be cheaper to buy a new one
Jul 04, 2009 • GPS
Driver side side mirror is broken. How to replace it?
if you can get a flat mirror cut to fit and stick it on with araldite
Top Apple Cell Phones Experts
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
Paul Bade
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
