Cars & Trucks Logo
a
andrew baird Posted on Jul 10, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Why is airbag light flashing?
How do i repair problem?
Stephen
Level 3:
Top Expert:
  • Nissan Master 21,873 Answers
  • Posted on Jul 11, 2014
 Stephen
Nissan Master
Level 3:
Top Expert:
Answers
21873
Questions
0
Helped
6210371
Points
67230
Depending on the code in the computer, you would need to test the component or circuit at fault.
Alan L
Level 2:
Sergeant:
Scholar:
  • Expert 130 Answers
Alan L
Expert
Level 2:
Sergeant:
Scholar:
Answers
130
Questions
Helped
20867
Points
765
According to the Nissan service manual the procedure to Reset the Air Bag System Warning Light is as follows:
1. Turn ignition switch from OFF to ON.
2. Air Bag warning light is on for 7 seconds and turns off, turn the ignition switch OFF within 1 second after the light goes out.
3. After ignition switch is turned OFF, wait for more than 3 seconds.
4. Repeat steps 1 to 3 twice. (Perform 3 times in total.)
5. Turn Ignition switch ON.
6. The SRS light should be reset.
If the warning light can not be reset I'd suggest you contact your Nissan dealer for more information and a proper diagnostics check as there be a fault with the airbag system.
Alan
SRS light is on
n most vehicles, the airbag light should come on for 6 seconds, and then go off if the system is working properly. If there is a fault or a problem in the system, the light will remain illuminated, or flash continuously. If the airbag light does not work properly, some vehicles have an audible tone that sounds indicating a problem with the airbag lights system. When the light is on( or the tone is sounding), the airbag will not deploy, even in an accident.
The flashing light on your car is telling there is a problem. On some vehicles require a OBD2 code scanner for the diagnosis. Once you know the code, you can most likely repair it yourself. There are fairly easy procedures that most people are capable of repairing.
Air bag light on how turn off
no other way to make airbags light OFF once it was ON or flashing. you have a repair shop diagnose your airbags warning light with a scan-tool. this provide the technician the DTC code and advise if the airbag clock-spring needs replacement.
Airbag lite flahes twice then three times & stays on.
Sorry about your car. On most vehicles, the airbag light should come on for @6seconds, and then go off if the system is working properly. If there is a fault or a problem in thesystem, the light will remain illuminated, or flash continuously. If the airbag light does not work properly,some vehicles have an audible tone that sounds indicating a problem with theairbag light system. When the light ison (or the tone is sounding), the airbag will NOT deploy, even in anaccident. The flashing light on your caris telling there is a problem. On somevehicles, the light is flashing a two digit code. Your vehicle does NOT require a scan toolfor the proper diagnosis. Airbagsolutions.com has the fault code charts to tell youwhat is wrong! Although it's a pay site ($14.95/day), it's a lot cheaper thangoing to the dealer. A subscriptionthrough the website will give you the procedure for diagnosing and resettingairbag light. This site that will explain everything you need to knowabout airbag lights and resetting the system. Once you know the code, you can may be able to repair it yourself. There are fairly easy procedures that mostpeople are capable of repairing. http://www.airbagsolutions.com/ http://www.airbagsolutions.com/scanlist.aspx
Air bag light lit after doing an engine wash on 99 Lincoln Navigator
On most vehicles, the airbag light should come on for @6 seconds, and then go off if the system is working properly. If there is a fault or a problem in the system, the light will remain illuminated, or flash continuously. If the airbag light does not work properly, some vehicles have an audible tone that sounds indicating a problem with the airbag light system. When the light is on (or the tone is sounding), the airbag will NOT deploy, even in an accident.
The flashing light on your car is telling the answer you need. On some vehicles, the light is flashing a two digit code. Once you know the code, you can most likely repair it yourself. There are fairly easy procedures that most people are capable of repairing.
http://www.airbagsolutions.com/light.aspx
This website gives you the procedure for diagnosing and resetting airbag lights. See if your car is listed here.
http://www.airbagsolutions.com/vehicles_list.aspx
Air bag light flashing
It means there is a problem with your airbag system, and you have no airbags at this time. You should get it repaired as soon as possible. Chancing a collision without airbags can be deadly.
Flashing Airbag Light Prior to Startup
2answers
Airbag light flashing
Code 34:
Driver Side Air Bag Circuit Low Resistance or Shorted> Let us know if we can assist you further
Airbag light
This is either a problem with one or both of your airbags or the airbag connector located at the back of the glovebox has been disconnected for some reason. (ie. to prevent airbag opening when installing baby seat) (1999 miata does not have a baby seat airbag disabling sensor).
You should get your car inspected at your local mazda service to check if this is a wiring (plug disconnected) issue or one of your airbags is malfunctioning and needs to be replaced.
Flashing airbag light could indicate that either one of the airbags or both have a problem. Disconnecting the passenger's airbag has the same effect.
Warning! Do NOT attempt to do any kind of airbag/airbag wiring related repair yourself. Airbag problems should be addressed ONLY by certified technicians at your local Mazda service. (Airbag fixing requires for example that the car battery is disconnected, you MUST NOT attempt anything with the car battery connected).
Hope this helps.
Top Nissan Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Arnie Burke
Arnie Burke
Are you a Nissan Expert? Answer questions, earn points and help others
