Singer Quantum XL-5000 Computerized Sewing Machine Logo
A
Anonymous Posted on Jul 04, 2014
How do you darn? - Singer Quantum XL-5000 Computerized Sewing Machine
matty_w
Level 2:
Legend:
An expert who has written 200 answers of more than 400 characters.
  • Singer Expert 631 Answers
  • Posted on Nov 26, 2014
matty_w
Singer Expert
Level 2:
Legend:
Answers
631
Questions
0
Helped
183102
Points
809
Your first step is to put a backer--stabilizer, pelon, or material underneath the area to be darned. You can use spray adhesive, or use an iron-on backer.
Generally, you should use the zigzag stitch that is several stitches--not the one that does one stitch in one direction and the next in the opposite direction. Make sure that the stitch is wide enough to cover the area next to the tear and hold it securely. It is a good idea to stitch over the tear several times.
2answers
Can feed dogs on janome 1600 series be dropped
No the feed dogs aren't dropped on the Janome 1600 series sewing machines. Instead, you cover them with the darning plate. I haven't found the darning plate sold separately. https://www.sewingmachinesplus.com/jan-767-827-009.php is a source for the darning foot and darning plate. As far as I can tell, the darning plate is not among the original accessories for any of the Janome 1600 models. The manuals for two of the Janome 1600 models are on the retired machine page: https://www.janome.com/support/retired-machine-manuals/ . The manual for the Janome 1600P-QC is on that machine page: https://www.janome.com/machines/sewing/1600p-qc/ . The direct link to this manual is https://www.janome.com/siteassets/support/manuals/professional-series/inst-book-1600pqc.pdf .
I hope this helps.
3answers
Where is the feed dog switch on the singer athena 2009 sewing machine
I'm not able to find a reference to a feed dog switch for your machine.
Singer Athena 2000 Instructions Manual Page 9
Could possibly be accomplished using a special plate? The instructions do refer to a darning foot, so the machine should be able to deactivate the feed dogs.
How to drop the feed dog on my Amelia Babylock
The Baby Lock Amelia (BL100A) does not have an option to lower the feed dogs. To use the sewing machine for darning, you need to place the darning plate over the feed dogs. The darning plate is included among the original accessories.
The manual for the Amelia is available from Baby Lock on the product page: http://babylock.com/sewing/amelia/ . See the FAQs & Manuals tab. The direct link to the manual is http://babylock.com/ftp/whitepapers/BL100A_Instruction%20&%20Reference%20Guide_Final.pdf . For the picture of the darning plate, see page 8. Page 27 describes attaching the darning plate.
Unfortunately, I haven't found a source for a replacement darning plate for the Amelia. I hope this helps.
1helpful
I don't know how to use the darning on my bernina 950. Can you advise
You need to use a darning presser foot--there are several designs of darning feet made by Bernina or generic brands (be sure the generic model has the appropriate attachment for your particular Bernina). You can find metal or plastic, clear or solid foot, open or closed toe, spring-loaded hopper or not, etc. Drop the feed dogs. If it is thinner fabric (lighter weight than denim), it sometimes helps to put the fabric in an embroidery hoop (upside down with the fabric next to the needle plate). If the hole is small, you can use the little hoop that should have been included in your Bernina accessory kit. Then you manually move the fabric back & forth, up & down under the presser foot while stitching.
12 BERNINA presser feet Darning foot 9
How to Use the Big Foot Darning Quilting Embroidery
Choose Your Darning Foot Quilting Foot and Learn to Machine Quilt
I have the dreamweaver machine and it uses the button foot for darning. makes a great stitch vertical but how to you make it make the horizontal stitch
Usually the stitch width selector would do that.
Um, just curious. If you are darning, you would manually maneuver the fabric to go forward and back and side to side. You probably wouldn't want to use a wide stitch for darning. Also, for darning, you would probably want to use a darning foot or free motion foot. They are both shorter than the standard presser foot so there would be no pressure applied to the fabric, especially when you drop the feed dogs. Technically, the feed dogs wouldn't be feeding the fabric, you would by hand.
https://www.youtube.com/watch?v=GtLj0iJnvqM
How to bring sewing foot holder to embroidery position
Hi, I hope this helps. If it doesn't post again.
"Check:
Place the sewing foot under the sewing foot
holder so that the pins of the foot snap into
the sewing foot holder when the presser foot
lifter is lowered.
Please check that the sewing foot is properly
engaged by raising the presser foot lifter
Question: Are you using top feed? If so:
"For all sewing jobs with the top feed, only use sewing feet with Cutout at the back (OA, 1A, 3, 4)."
Embroidery foot Part No.: 98-694-840-00 will not work with top feed.
Also, except for eyelets, the darning foot can be used for embroidery.
I'm not sure what you're trying to do :) darn or embroider :); I'm not sure what mode you're working in either; embroidery mode?
Darning with straight stitch
Program 00
Fit darning foot No. 6.
Set the needle at its highest position by turning
the handwheel, and push the pin of the darning
foot fully into the hole of the sewing foot holder
slightly pressing the darning foot between thumb
and forefinger. When doing this, the guide fork
should place itself around the presser bar and the
wire must be behind the fixing screw.
Darning position:
Lower the presser foot lifter pressing it lightly to
the rear until it snaps into the darning position.
Important Only in this position you have the
optimum thread tension for darning.
• Place the darning work in the darning hoop.
• Lower the feed dog.
• Pull up the bobbin thread and hold the threads
when you start sewing.
• Now guide the fabric back and forth evenly;
the length of the darn will be set by the size of
the hole. As you are determining the stitch
length yourself while sewing with the feed dog
lowered, you should sew at an even speed.
When you have reached the width of the dam
aged area, darn over the damaged area again
from right to left.
This guarantees a durable darn.
TIP: The faster you sew, the easier and more even
the darning will be. It you are moving the workpiece
too slowly, small knots will appear on the
wrong side of the fabric."
Whether working with terry-cloth or woven fabric,
with the help of the darning foot and the pro
gram 02 you can embroider initials of your own
design
Drop the feed dog and insert the darning foot.
Put the machine into the darning position.
Spread the fabric in an embroidery hoop and
embroider in accordance with program 02.
Lower feed dog
If the feed dog is not lowered for embroidering, the
machine does not embroider when the foot pedal
is pressed and the message appea rs:
Lower feed dog
ok?
The feed dog must be lowered in embroidery
mode.
How to darn
If you want to darn them by hand, here is an excellent tutorial: http://www.myzigzagstitch.com/2009/02/26/how-to-do-it-darn-socks/
Hand darning is easier than darning by machine.
Free motion quilting with the Singer 3343
I don't use a foot - I just gently guide the fabric and create designs.Hope this helps.Jimmy
How do i install the darning foot?
Make sure that you have a darning foot that is compatible with your machine. I believe that the 7422 is a low shank foot; the appropriate daning foot is http://www.sewingpartsonline.com/darning-foot-singer-006016008.aspx . Lift the presser foot and remove the foot currently on the machine, including the ankle. (Loosen the screw on the left side of the ankle.)
Place the darning plate over the regular plate and feed dogs. The pins should lock into the spots on the machine.
Place the U-shaped opening of the darning foot over the screw that you loosened previously. Then tighten the screw to hold the foot on the machine.
Lower the presser foot onto your fabric. Set your stitch length. Lower the lever on the right side of the darning foot and hold onto your top thread (assuming the needle and bobbin thread are already threaded.) Now sew.
I hope this helps.
Aug 10, 2011 • Singer 7422
Top Singer Sewing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
