1994 Toyota Pickup Logo
Posted on Jun 28, 2009
Automatic transmission linkage adjustment. Is there a procedure in writing to follow or a flow diagram to look at. My transmission has been rebuilt and now the changing of gears takes place at higher RPMs. 1 to 2d gear shifts at around 25 MPH; 2d to 3rd at around 45 to 50 MPH. Overdrive kicks in around 63 MPH. Can this be changed?
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Oct 19, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
1471
Points
REPLACE A SERPENTINE BLET
2002 ford f150 4.6 motor when I drive it will not shift gears on its own it will shift if I manually do it my self I have no idea what's going here
Diagnostic starting point .
SECTION 307-01B: Automatic Transmission - 4R70W 2002 F-150 Workshop Manual DIAGNOSIS AND TESTING Procedure revision date: 06/20/2001 Diagnostic Strategy Troubleshooting an electronically controlled automatic transmission is simplified by using the proven method of diagnosis. One of the most important things to remember is that there is a definite procedure to follow.
NOTE: Do not take any short cuts or assume that critical checks or adjustments have already been made.
Follow the procedures as written to avoid missing critical components or steps.
To properly diagnose a concern have the following publications available:
  • Transmission Reference Manual.
  • Powertrain Control/Emissions Diagnosis (PC/ED) manual.
  • TSBs and OASIS Messages.
  • Wiring Diagram.
These publications provide the information required when diagnosing transmission concerns.
Use the Diagnostic Flow Chart as a guide and follow the steps as indicated.
Preliminary Inspection
  • Know and understand the customer's concern.
  • Verify the concern by operating the vehicle.
  • Check the fluid levels and condition.
  • Check for non-factory add-on items.
  • Check shift linkages for proper adjustment.
  • Check TSBs and OASIS messages regarding the concern.
Diagnostics
  • Carry out on-board diagnostic procedures key on engine off (KOEO) and key on engine running (KOER).
  • Record all diagnostic trouble codes (DTCs).
  • Repair all non-transmission codes first.
  • Repair all transmission codes second.
  • Erase all continuous codes and attempt to repeat them.
  • Repair all continuous codes.
  • If only pass codes are obtained, refer to Diagnosis By Symptom for further information and diagnosis.
Follow the diagnostic sequence to diagnose and repair the concern the first time.
It's best if you take your vehicle to a qualified repair shop if your not familiar with any of thing's listed above .Need a scan tool to check for DTC'S .
Your
1helpful
2000 Ford F250 SD xlt 4 WD 5.4 liter 4 speed A/T The over drive button was flashing So I purchased the gear shift lever w/button After changing out I'm having delayed and slipping in A/TransHelp Pleas
SECTION 307-01: Automatic Transaxle/Transmission 2000 F-Super Duty 250-550/Excursion/F-53 Motorhome Chassis Workshop Manual DIAGNOSIS AND TESTING Procedure revision date: 06/21/1999 Diagnostic Strategy NOTE: Do not take short cuts or assume that critical checks or adjustments have already been made.
To diagnose a concern correctly, the technician should have the following publications available:
  • Transmission reference manual.
  • OASIS messages.
  • Technical Service Bulletins (TSBs).
  • Wiring Diagram.
Using the Diagnostic Flowchart as a guide, follow the steps as indicated.
  • Check the fluid level and condition.
  • Check shift linkages for correct adjustment.
  • Check TSBs and OASIS messages for the concern.
Diagnostics
  • Vehicles that have power take-off capability will not have on board diagnostic capability when the power take off is in operation.
  • Carry out on-board diagnostic procedures key on/engine off (KOEO) and key on/engine running (KOER).
  • Repair all continuous codes which reappear.
  • If only pass codes are obtained, refer to Diagnosis By Symptom in this section for further information and diagnosis.
Transmission Control Switch (TCS), Transmission Control Indicator Lamp (TCIL)
The transmission control switch (TCS) is a momentary control switch. When the switch is pressed, a signal is sent to the powertrain control module (PCM) to allow automatic shifts from first through fourth gears or first through third gears only. The PCM energizes the transmission control indicator lamp (TCIL) when the switch is off. The TCIL indicates OVERDRIVE cancel mode activated (lamp on) and electronic pressure control (EPC) circuit shorted (lamp flashing) or monitored sensor failure.
Your best bet is to take your vehicle to a qualified transmission repair shop !
Your
My 1992 mercury topaz shift hard when coming to a stop. recently had transmission replaced. maybe missing transmission shift cable. is there such a part
unit has shift linkage between throttle and transmission linkage, it has plastic bushings that hold it in place, they will get brittle with time and break, allowing linkage to come off or be out of adjustment. Have whoever rebuilt it have a look at them and replace them. There plastic, cost should be a few dollars.
HAVE A 1989 FORD F-150 WITH AUTO TRANS THAT YOU CAN'T SHIFT OUT OF THE "PARK" POSITION AT THE STEERING COLUMN. THE TRANY CAN BE SHIFTED AT THE TRANS WHEN LINKAGE IS DICONNECTED.I THINK THE...
What trans? AOD? This is 1992 F Series, all I have.
Shift Controls, Automatic Transmission The transmission shift control linkage or cable transfers the transmission operating mode from the selector lever to the transmission. The indicated transmission position on the steering column is transferred to a shift lever on the bottom of the steering column. On vehicles equipped with cable-operated shift systems, the indicated position of the transmission selector lever is transferred to the transmission through the shift cane, then to the cable, and down to the transmission manual shift lever at the transmission. On vehicles equipped with shift rod assemblies, the rod transfers the indicated transmission selector level position through a bell crank assembly to a control rod. The control rod transfers the indicated position to the transmission assembly.
Automatic Transmission Manual Linkage Adjustments
  1. With the engine stopped and the parking brake applied, place the transmission selector lever at the steering column in the D (DRIVE position) for C6 applications and in the (D) (OVERDRIVE position) for AOD and E4OD applications, and hold against the D or (D) stop by applying a three-pound force to the selector lever knob.
  1. Loosen the shift rod adjusting nut at point A. Refer to the following illustrations.
  1. Shift the manual lever at the transmission into the (D) (overdrive) position for E4OD, by moving the lever all the way rearward, then forward two detents.
  1. With the selector lever and transmission manual lever in the(D) position, tighten the nut at point A to 17-24 Nm (12-18 ft-lb) torque. Use care to prevent motion between the stud and rod.
  1. Remove the three-pound force from the steering column selector lever knob.
  1. Operate the shift lever in all positions to make certain that the manual lever at the transmission is in full detent in all gear ranges. Re-adjust the linkage if required.
  1. On F-Super Duty Chassis Cab and Motorhome and Commercial Chassis recheck for correct operation of the automatic transmission selector indicator (PRN(D)21). Refer to Section 11-04A, Steering Column, Shift Rod Within Tube. ani_caut.gif CAUTION: Under no circumstances will it be permissible to adjust linkage in any position other than the(D) position for E4OD applications.
Automatic Transmission Shift Cable Adjustment
  1. From inside the vehicle, place the column shift select lever in the DRIVE position (C6) of the OVERDRIVE (AOD and E4OD). Hang a three-pound weight on the selector lever.
  1. Raise vehicle on a hoist.
  1. Remove the shift cable from the transmission lever ball stud.
  1. Pull down the lock tab on the shift cable body.
  1. Position the transmission shift lever in the DRIVE position (C6) or the OVERDRIVE position (AOD and E4OD). This is three detents from the front-most lever position with the first position counting as one.
  1. Connect the cable end fitting to the transmission lever ball stud.
  1. Push up on the lock tab to lock the cable in the correctly adjusted position.
  1. Lower vehicle down from hoist and remove the three-pound weight from the column shift select lever.
  1. After making the adjustment, check for park engagement. Check the transmission control lever in all detent positions with the engine running to make sure correct detent/transmission actions. Readjust if necessary.
2answers
Is the back up switch connected to the shifting linkage of the automatic transmission on my 1988 ford bronco II
If you have the C5 trans, here is the info:
C5 Transmission
  1. Disconnect the negative battery cable.
  2. Raise and support the vehicle safely.
  3. Remove the downshift linkage rod from the transmission downshift lever.
  4. Apply rust penetrant to the outer lever attaching nut to prevent breaking the inner lever shaft. Remove the transmission downshift outer lever attaching nut and lever.
  5. Remove the two neutral start switch retaining bolts.
  6. Disconnect the multiple wire connector.
  7. Remove the neutral start switch from the transmission.
To install:
  1. Install the neutral start switch on the transmission. Install the two retaining bolts.
  2. Adjust the neutral safety switch following the above procedure.
  3. Install the outer downshift lever and retaining nut, and tighten the nut. Install the downshift linkage rod with the retaining clips.
  4. Connect the wire multiple connector. Check the operation of the switch. The engine should start only with the transmission selector lever in N or P.
If it is the:
C3 And A4ld Transmissions
It's on the transmission....
// // 0) preLoad.src = ctl00_cphLeft_chRepairTreeNav_tvTOC_ImageArray[i]; } ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.lastIndex = 35; ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.populateLog = theForm.elements['ctl00_cphLeft_chRepairTreeNav_tvTOC_PopulateLog']; ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.treeViewID = 'ctl00$cphLeft$chRepairTreeNav$tvTOC'; ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.name = 'ctl00_cphLeft_chRepairTreeNav_tvTOC_Data'; //]]> c17hydro_179.gif
Neutral start switch and its location on the C3 and A4LD transmissions
Transmission pops out of reverse after installing new clutch,HELP?
U most likely have gotten the transmission linkage out of adjustement, the procedure to adjust it is very involved and requires u have a factory service manual to foolow on the correct procedure, a hit and miss adjusment won't do it, u can make it worse, if the transmission linkage turns out to be in adjustment then u have an internal transmission problem
Automatic Transmission goes into all forward
check fluid if it is a dark color and stinks transmissions probably needs rebuilt sounds like low reverse or direct clutch is bad trna will still go into loe by using forward clutch if low reverse is bad shoul be having problems with 3rd or direct in forward if forward clutch is bad
1996 Chevy cavalier is stuck in neutral
There are no easy fixes with automatic transmission but you could have the shift linkage checked to see if it can be adjusted. The neutral adjust switch may be out of adjustment or malfunctioning. It could be a number of problems but I would take it to an expert you trust because it may be something simple and they will tell you that you need your transmission rebuilt.
1999 saturn sl2 5 speed transmission will not go into reverse 2nd gear sometimes will not engage is there a linkage adjustment.
There is no 'adjustment' but you can check your linkage for security making sure nothing is loose or worn. Also check your fluid levels. If reverse is completely out and your starting to lose second you will probably need to have the transmission rebuilt or replaced.
2helpful
2answers
Transmission on a 1983 f100 with a overdrive automatic. it's shifting well now that I adjusted the kickdown linkage but won't shift into overdrive until about 50-55 mph and only if I let off the gas a...
The best way to adjust it is to hook a pressure gage to the TV pressure port located on the left side of the transmission just ahead of the linkage. You want it to be a zero at idle but pressure starts moving as soon as you move the linkage.
Top Toyota Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
ROBERT GARCIA
ROBERT GARCIA
Are you a Toyota Expert? Answer questions, earn points and help others
