Epic View 550 Treadmill Logo
A
Anonymous Posted on Jul 01, 2014
How do i search for chanels with the tv on my epic view 550 treadmill
5 Related Answers
Anonymous
  • 1902 Answers
  • Posted on Feb 21, 2009
SOURCE: The Incline is stuck at an angle
Check the motor and the gears that run the unit up and down. If is located on the front of the unit under the face plate. make sure everything is power everything. Also check the gears to make sure they did not break and check the tracks to make sure it did not fall off the track causing it to stay up
Anonymous
  • 40 Answers
  • Posted on Sep 29, 2009
SOURCE: How do you put the treadmill down?
There is a knob on the support bar behind the treadbelt deck. Give the deck a little push up, then pull the knob out and lower it.
Anonymous
  • 11896 Answers
  • Posted on Feb 19, 2010
SOURCE: treadmill powers up but belt will not rotate
Check to see if the motor is spinning. If not spinning, then use a voltmeter to find out the voltage of power going to the motor that spins the belt. See if you can rotate it by hand.
maxtreadmill
John Mazmanian
  • 832 Answers
  • Posted on May 06, 2010
SOURCE: I left the red key in epic view 550 for 1 full
Check the reset/off circuit breaker located on the treadmill frame near the power cord. If the switch protrudes as shown, the circuit breaker has tripped. To reset the circuit breaker, wait for five minutes and then press the switch to the reset position.
Anonymous
  • 218 Answers
  • Posted on Aug 10, 2010
SOURCE: I put it "up" for
push it forward before trying to pull knob and make sure the incline is at the lowest level.
Epic 550 treadmill
If you wish to get some derails about treadmill repair then check the below added link
http://electro-medical.blogspot.com/
Why doesn't it start?
epic view 550 treadmill video 2 - YouTube
? 2:08
https://www.youtube.com/watch?v=fSIuoh_bZN4
Mar 9, 2010 - Uploaded by Epictreadmillowner
epic view 550 treadmill video 2 ... ICON Canada doesn't really support this and the independant technicians ...Epictreadmillowner 1,181 views.
Epic View 550 Treadmill Review - YouTube
? 3:02
https://www.youtube.com/watch?v=kNiFOcrV9r4
Nov 29, 2012 - Uploaded by Treadmill Review Guru
... .com/epic-treadmill-reviews/epic-view-550-treadmill-reviews-ratings/ ... Nordic track has the track and google maps by i-fit you can download and run anywhere ... The review says it doesn'thave the track/lap but it does.
Epic View 550 Treadmill video 3 - YouTube
? 1:59
https://www.youtube.com/watch?v=YjqgZS-1qlw
Mar 11, 2010 - Uploaded by Epictreadmillowner
Epic View 550 Treadmill video 3. Epictreadmillowner ... I have had 3 different console units, and now the tv doesn't work either!
Epic View 550 Reviews - MyTreadmillReview.com
mytreadmillreview.com/epic-view-550-reviews-2
Epic view 550 treadmill
RUN the software calibration, and test the machine
God bless you
4helpful
3answers
I am having trouble removing hood/motor cover on Epic 550 treadmill. I have removed 4 - 3/4" screws from front panel and 2 - 1/2" screws from underneath. Still feels locked on. Are there other...
If you lift your treadmill deck up, you will find 2 screws underneath, on the side, towards the front. remove them and that should do the trick.
10helpful
2answers
We have an Epic 550 treadmill and the TV is upside down. When we first got it the TV was fine but we must have down something to get it upside down and no clue what we did! HELP!
Just got off the phone with Icon. Here's the Fix: 1) With the remote control that came with the Treadmill press "Menu". 2) Then enter "1591" quickly with the number buttons. 3) Use CH or CH - to choose flip orientation. 4) Press VOL or VOL - to select 5) Press Exit
That should do the trick!
I put it "up" for storage and now I can't get it down to use... Epic View 550
I left the red key in epic view 550 for 1 full day, next day when discovered now treadmill will not start, no lights, no noise, nothing!! Help
How do you put the treadmill down? We can't seem to unfold the treadmill. It's an Epic View 550. Thanks!
Top Epic Exercise & Fitness Experts
ADMIN Andrew
ADMIN Andrew
Sportsmith LLC
Sportsmith LLC
Don A
Don A
Are you an Epic Exercise and Fitnes Expert? Answer questions, earn points and help others
