I have the exact same timer. The transformer hooked up to this *timer* is rated for 196W max & is model C150T (. I don't know if your is the same (but if timer is similar, it may be)
I'm trying to figure out how many lights I can hook up to this Transformer.... I removed the case front and here is all that it reads
ACTOWN 3879
EIA 1108 B2 P2
119L V102 9120
Model # PB115M1
Moter 125V.60HZ
(small numbers at the bottom)...154Sb10148
What would be the total amount of watts that can be added to this transform? Thanks :)
The timer you are referring to is used in an Inermatic LV341T "Malibu" low voltage lighting system. There is a sticker (might be missing in your unit) under the cover that indicates that not more than eight 11 watts lights are to be powered from it. The total output of the unit is limited to 88 watts at 12 volts. The list of numbers in the first three rows you listed are on the transformer. It steps the 115vac down to 12vac.
The timer has an amp rating for the contacts that switch the load you want to control. It will give you the contact rating on the door. For Wattage conversion, multiply the amps x volts= watts
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
