SOURCE: so water leaks out onto floor-Jennair side by side
THERE IS A DRAIN LINE HEATER ON MOST UNITS now days, if yours is an older one what you need to do is make sure that it's level, and that the drain line is cleared so that the water has a place to go when it thaws during the defrost cycle.
SOURCE: Defrost pan keeps overflowing
On the freezer side at the bottom of the freezer coil there is a drain. There should be a thin aluminium filiament attached to the defrost element and feeding down into the drain tube. This filiament conducts heat from the element down the tube preventing ice forming in the tube and keeping it clear.
SOURCE: water accumulating in bottom of freezer and leaking onto floor
Yes the drain is clogged and the water that supouse to go through became ice so it make it worse.Put hot water in the drain hole until it runs through,it'll go to an evaporative pan on top of the compresor to keep it warm and vaporize the water.
SOURCE: refridge leaking water inside it...
The condensate drain begins inside the freezer compartment behind the back panel and at the bottom of the evaporator coils. Every time the refrigerator defrost (about 3 times a day) the water needs to flow out the bottom of that pan in the freezer and into a plastic drain pipe to the bottom of the refrigerator into a pan on top of the compressor or side of compressor. Sometimes the drain is blocked inside freezer and there is a buildup of ice. But sometimes it is blocked near the opening that leads out of the fresh food compartment and then down to compressor tray/pan. If the blockage is near that exit then you will see a trail of water running down the back of the fresh food compartment and settle in bottom. The only solution is to slowly and carefully remove the drain pipe from the back and inside of refrigerator and clean it out. Let me know how you are doing on this and I will be here to help,Thanks Sea Breeze
SOURCE: refrigerator leaking water on floor under it!
The leak is most likely coming from the defrost tray below the evaporator coils. A piece of ice or something is preventing the water from draining to the pan below your refrigerator. Unplug and remove the back panel inside the freezer. Any blockage from that tray will cause the water to pool out into the freezer or fresh food section. Thanks, Sea Breeze
