1) Make sure that you have thoroughly backwashed the sand.
2) Make sure your chemical balances are correct
3) Remove filter canister top valve and insure that it was properly seated on the filters canisters center pipe.
4) Remove all sand from the filter canister
4) Clean all components thoroughly
5) Check for cracked laterals or plumbing
6) Repair or replace any bad or missing components
7) Reassemble
Tip: carefully use a rubber mallet to seat the canister valve by lightly tapping on and about the circumference of the valves seat.
Hope this helps,
https://www.oskopoolnspa.com
