So you have a "TA" filter. Which size?
It does not matter really, otherwise I would have been able to know how much sand you you have to remove and how much to put back in.
Anyway, To change sand you have to remove the MultiPort Dial valve on top.
Then, you can either unplumb the filter and roll it over on its side and using a garden hose, start washing the sand out or use a shop vac, with keeping it upright.
Whatever you do NOT damage the laterals on the bottom of the filter. When refilling with sand you want to make sure all the laterals are undamaged and in the down position. Always fill the filter half full of water, at least over the laterals by a few inches, to keep the sand from damaging the laterals while re-filling the filter with sand. Make sure you use pool filter sand and not play sand! And... cover the stand pipe!!! Use duct tape or some kind of covering (spout cut off a water bottle then covering the pipe). Otherwise you will get sand into the standpipe and into the laterals, then you have another problem.
SOURCE: How to change sand in Hayward S-200 Sand filter
hayward S-180 filter takes 150lbs, S-210 takes 200lbs not familur with the S-200. To change sand you have to remove the vari flow valve on top. You can either unplumb the filter and roll it over on its side and try washing the sand out or try scooping it out upright. Whatever you do dont damage the laterals on the bottom of the filter. When refilling with sand you want to make sure all the laterals are undamaged and in the down position. I always fill the filter half full of water to keep the sand from damaging the laterals while re-filling the filter with sand. Make sure you use pool filter sand and not play sand!
