Sounds like the cooling fan motor,or motors,are not working.Check the relays,and fuses for the cooling fans.If the ac is on,look to see if the cooling fan,or fans come on.If they do ,then most likely have an enternal ac system problem.The expansion valve is the most likely problem,or possible,the dryer.Have the ac system checked to see if it is low,or if the low side is going into a vacuum,if it is going into a vacuum,replace the expansion valve.First check to see if the cooling fans are working with ac on.If I can help,let me know.>>>
[email protected]
