Question about Mitsubishi Heating & Cooling
SOURCE: Fujitsu Split System AST24RGA-W + AOT24RZAL
with the remote.....turn the fan only on.if the fan does not run its either the board or wiring.
Posted on Aug 23, 2008
SOURCE: York Mini-Split Not Cooling? : (
This can only be a gas problem.
the split units goes on on and off if a shortage of gas is involved, the chances that you would here it wont be that big for the fans would make too much noise.
get a repair man for a re gas and all is well.
Good luck.
Wouter.
Posted on Oct 22, 2008
SOURCE: ac split unit indoor an ouydoor unit electrical wiring diagram
machine off
Posted on Apr 25, 2009
SOURCE: Fujitsu mini split outdoor unit not running, but indoor unit is running after turnning on
Check the disconnect switch and make sure that both the fuses are good and not shot. If one is shot then the system wont work. There are two fuse. Also be careful due to you will be working around 210 volts
Posted on Jun 01, 2009
Sep 14, 2018 | Hitachi Heating & Cooling
Jun 20, 2017 | Mitsubishi Heating & Cooling
Jul 25, 2016 | Mitsubishi Heating & Cooling
Aug 05, 2015 | AMVENT 18000 Btu 1.5 Ton Ductless Mini...
Oct 29, 2011 | Mitsubishi Mr. Slim MXZ30TN Air...
Jun 01, 2011 | Heating & Cooling
Feb 18, 2011 | Mitsubishi MSZ-A15NA Split System Air...
Jan 19, 2011 | Heating & Cooling
Apr 10, 2010 | LG LS-K2430HL Heat Cool Mini Split Air...
Mar 09, 2010 | Heating & Cooling
60 people viewed this question
