Home | Mitsubishi | Air Conditioners
Mitsubishi Mr. Slim MXZ30TN Air Conditioner
Problems with Mitsubishi Mr. Slim MXZ30TN Air Conditioner?
Ask our Experts
Chat with a Pro
Tell us why
Share your Experience
Do you recommend the
Mitsubishi Mr. Slim MXZ30TN Air...
Problems
& Solutions
Manuals
& Guides
Repair
Service
Top
Experts
Warranty
& Spec
Troubleshooting and Support
Solved Problems for Mitsubishi Mr. Slim MXZ30TN Air Conditioner RSS Feed
View More Results for Mitsubishi Mr. Slim MXZ30TN Air Conditioner
Questions and Unsolved Support Problems
Unsolved Problems for Mitsubishi Mr. Slim MXZ30TN Air Conditioner RSS Feed
Answer
Mr. Slim MXZ30TN AC Unit displaying code U1. How do I solve this, what does it mean?
Answer
Wich hydraulic oil type choose for my mitsubushi mx-55 excavator? Thanks! -Martin
Answer
outdoor unit cutting off after 10 minutes error code p8-00 any suggestions
Answer
I have a Mitsubishi Mr Slim model MSZ12UN. The air conditioning blows cold at the right side of the... (More)
Find a Manual
Mitsubishi Mr. Slim MXZ30TN Air Conditioner Manuals & Guides
Sorry. We do not have a manual for this product.
You can...
  • Search for manuals of related products.
  • Ask an Expert to find it!
Tips & Tricks
(Post a New Tip)
Replace the unit? or Replace the compressor? Split AC or Heat Pump
I had this fellow ask why he couldn't find any thing about id model number for buying a replacement out door ac unit. The answer I game him is part... written by farfield
Relay Wiring tips and tricks Simple circut. What to look/lookout for
Typically if you want a circuit completed when energized you use C (Common) and NO (normally open). This means that the contact will close when... written by farfield
Don't jump to "Its low on charge; because its froze up"
A low charge diagnosis for instance can be miss read if the evaporator is iced up or has any ice in or on it. A sticking thermostat, relay, or... written by farfield
How to Trouble shoot Low Voltage Controls on AC-Heat
What I have always been told is if your 24 volt side burns out check the high volt side if the hi volt side burns out check the low volt side. A... written by farfield
COMPRESSOR check outs semplified.
If your wondering how to check out your refrigeration compressor; Modern Compressors have two operations that have to work together just to run.... written by farfield
Air Filter changing - easey and often
Examine the air filter at the beginning of each cooling and heating season and at the beginning of each day light savings time change. Write the date... written by farfield
AC DRAINAGE PIPING REQUIREMENT
Slide 71 .O {color:black; font-size:149%;} a:link {color:#CCCCFF !important;} a:active {color:#3333CC... written by bobotfel
HOW TO CHECK A GOOD REMOTE CONTROL
HOW TO CHECK A GOOD REMOTE CONTROL Using Camera or Cellphone Camera, use the camera as your eye point the remote control transmitter to the camera and... written by bobotfel
WikiManual
(Post a New Chapter)
How to Keep the Upstairs of Your Air Conditioned Home Cooler
Suffering in summer heat in the upstairs bedroom? Make the most of the air conditioning by following these steps. Steps: 1. Add attic insulation.... by wikihow
How to Build Your Own Air Conditioner
If your tap water is cool, you can air condition a room with it at minimal cost. Steps: 1. Obtain a radiator from a small car such as a Honda Civic,... by wikihow
How to Check Your Air Conditioner Before Calling for Service
Steps: 1. Change your filter regularly. This simple step alone can increase the efficiency of your air conditioner. It will also run less, increasing... by wikihow
Upload Manuals
I need help with
near zipcode:
Please enter your zipcode
Search
Click here to get instant support from our best Experts!
Top Repair Providers for Mr. Slim MXZ30TN Air Conditioner
Nationwide | | Website
Service and Repair, System Maintenance, Advantage Mem... Read More
Featured Listing
ARS
Nationwide | 8668003823 | Website
When it comes to air conditioning systems, ARS® pro... Read More
Featured Listing
Find an Expert
Meet our 2629 Air Conditioner Experts
dmftrucker
Rank: GuruGuru
Rating:  87%, 401 votes
Solutions:  1582 (485 Votes in the last 30 days)
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
projdoc
#2: projdoc
Rank: GuruGuru
Rating:  94%, 597 votes
Solutions:  1178 (463 Votes in the last 30 days)
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
roniecon
#3: roniecon
Rank: GuruGuru
Rating:  88%, 635 votes
Solutions:  2120 (394 Votes in the last 30 days)
Experience: A S E certified /35 years experience
57 varieties
Rank: GuruGuru
Rating:  88%, 509 votes
Solutions:  1495 (350 Votes in the last 30 days)
Experience: I have been solving problems and fixing things for over 30 years!
justaskjoe
Rank: GuruGuru
Rating:  85%, 1971 votes
Solutions:  3800 (340 Votes in the last 30 days)
Experience: 30 yrs exp home bldg, plumbing, wiring, framing, design & spring water usage. Problem solving.
localwonder
Rank: GuruGuru
Rating:  92%, 2763 votes
Solutions:  4883 (322 Votes in the last 30 days)
Experience: I have yrs of experience dealing with many situations.
avid101
#7: avid101 Expert Moderator
Rank: GuruGuru
Rating:  87%, 1135 votes
Solutions:  2414 (284 Votes in the last 30 days)
Experience: ASE Certified Master Car and Truck Mechanic Certified AC mechanic Cert. AWS Cert. welder Contract me
techbuster
Rank: GuruGuru
Rating:  89%, 485 votes
Solutions:  1086 (282 Votes in the last 30 days)
milten1
#9: milten1
Rank: GuruGuru
Rating:  90%, 471 votes
Solutions:  1304 (241 Votes in the last 30 days)
Experience: 15 years field experience and 5 years navy training
buffalonyman
Rank: GuruGuru
Rating:  85%, 709 votes
Solutions:  1815 (226 Votes in the last 30 days)
Experience: Licensed Master Electrician for 25 years, Plumbing, HVAC, Custom Build Computers, Automotive
Find a Warranty
Specifications for Mitsubishi Mr. Slim MXZ30TN Air Conditioner
Other Features
Filter
Reusable
Key Features
Type
Stand Alone/Portable · Split System
Remote Control
With Remote Control
Cooling Capacity
28400 BTU/hr · 25000 BTU/hr · 21700 BTU/hr
Energy Efficiency Rating
11 EER
Additional Characteristics
Ductless · Dual Zone
Dimensions
Depth
12.63 in.
Height
35.44 in.
Width
35.44 in.
Warranty
Warranty
1 Year
Electrical Requirements
Voltage
208 / 230
Cooling Ampacity
8.9 / 9.9
Cooling Watts
2280
Heating Ampacity
9.4 / 10.4
Heating Watts
2400
Supported Models
9+12, 9+15
Mitsubishi Contact Information
Main support number800-332-2119
Support FAX(714) 229-3854
Email supportCustomerCare@meus.mea.com
Describe your problem:
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
