My krave cell phone is locked and i forgot my passcode
SOURCE: I forgot my keylock code for my Lg Fusic sprint cell phone
what you can do is press ##DATA# (##3282#) then go to ADVANCE, VIEW, and last LOCK CODE..... there you go now you are able to see the lock code in which your for is currently on!
Mario C.
Have a Nice DAY!!
SOURCE: lock code
unless you know the pass code you cannot unlock the phone...
only way is to reinstall the phone software
SOURCE: My cell phone is locked.
To unlock a Samsung turn the phone off take the sim card and type the following code *#pw+15853649247w# .
Java status code: #*53696# (Samsung X600)
If you want to unlock your phone put a sim from another company then type *#9998*3323# it will reset your phone. Push exit and then push 7, it will reset again. Put your other sim in and it will say sim lock, type in 00000000 then it should be unlocked. Type in *0141# then the green call batton and it's unlocked to all networks. This code may not work on the older phones and some of the newer phones. If it doesn't work you will have to reset your phone without a sim in it by typing *#2767*2878# or *#9998*3855# (not tested)
SOURCE: Forgot Lock Code - Samsung m500 Cell Phone
try to use last 4 digit of your phone number . go into the menu then setting then security then enter four digets and you can find these 4 degits into in setting then phone info enjoyyyyyyyyyyyyyy
SOURCE: Can't unlock phone I forgot
You need to perform a hard reset on the phone. Follow these directions:
hese steps will wipe all data from the device.
1. Power off the phone. If the phone is frozen and won’t turn off using the Power button, pull the battery out.
2. With the device off, press and hold the Power andCamera buttons.
3. Release the Camera button when prompted to do so.
4. Press and hold the Volume Down button until a yellow exclamation mark appears on the screen.
5. Open the physical keyboard and press ALT + L, then press ALT + W to complete the hard reset of the Cliq.
That should do it! Good luck!!
