20 Most Recent
Nokia Verizon Wireless Lumia 928 Windows Phone Questions & Answers
I forgot the password for my nokia lumia
928
how do i unlock it
Note An alternate reset method is available if the device can be powered on and is responsive.
Ensure that the device is powered off.
Press and hold the Volume Down button (located on the right-edge of the device; above the power button) until instructed to release in step 4.
Press and hold the Power button until the device vibrates (approximately 2 seconds) then release.
Note Alternatively, connect the device to an approved USB charger while continuing to hold the volume down button.
When the restore screen appears (exclamation mark), release the Volume Down button.
From the restore screen, press then release the following buttons to initiate the reset process:
Volume Up
Volume Down
Power
Volume Down
Note Allow several minutes for the process to complete (rotating gears appear on the display to indicate that the reset is in process).
Note To setup the device after the reset has completed, refer to Initial Activation and Setup.
Can you help me unlock my phone I forgot my passcode lock
While the device is off hold the home button and the volume up button at the same time as the power button until a special menu appears you can then reset the phone to factory settings which will which may erase all your personal content but the phone will be as though you had just purchased it
My Nokia 928 worked great for a year, now all of a sudden, it's over heats extremely and it will not charge at all. I am using the charger that came with the phone when it was purchased. Anyth
- Is it overheating only when charging? Use the Nokia battery charger that was included with your phone. Older chargers may not fully charge the battery.
- Reset your phone. Press and hold the Power and Volume down keys simultaneously until you feel the phone vibrate. After this operation, you may need to set the date and time on the phone. Note that this does not remove any settings or your personal content. You might try this too! Make sure you have the latest software update; of course you have to have enough battery power to do this:
- updating your phone software, and you can get fresh new features and improved performance too. Your phone supports wireless Over the Air (OTA) updates and there is no need for cables or computer, just download and install the update using your phone. Also, your settings, apps, photos, and text messages remain safe and sound.
Your phone notifies you when an update is available for you. You can also check for updates, just tap Settings > Phone Update.o view and to install the updates, tap the notification message, and follow the instructions shown on your phone. You can install the update immediately, or postpone the update to a more convenient time.The update should take around 15-30 minutes, but a major update could take up to 2 hours to complete depending on your phone model. You are not able to use your phone during the update installation. Follow all the update prompts, and do not worry if your phone restarts several times during the process, that is completely normal.
- Otherwise contact Microssoft.com
Restriction code for Nokia 2690
It is normally recommended you Don't post your IMEI on websites. It is a security code for that phone.
Usually the IMEI number has to be reset by your network provider. It normally cannot be done directly from the handset. Did the handset accept the new sim card. Some handsets can be locked to a specific network and changing network can stop your phone from working.
Nokia 2730C-1. can I unlock the network
If the phone was not used 2012, the phone number and phone have been deactivated from the network you used to pay for service. You need to set up a new contract as they expire after about 2 years of inactivity.
