Hook it up to an external monitor. If the display is fine on the external then your gpu on the motherboard is fine and the LCD is bad. No external display means bad board. Both cost roughly the same but an LCD is much easier to replace than the board.
try to hook an external monitor. if it will still have same problem then you should replace video card. if not, then its the LCD screen that should need replacing.
This is usually the actual screen driving transistors packing up, real common. replace the screen, if cheap enough, often though they are more than a new machine.
it could be the lcd cable. Try replacing that. If that doesn't work then it would have to be the LCD screen Steve cause pushing on it and having lines come up is going to be lcd screen or lcd cable.
I'm referring to the lcd cable that runs from behind the LCD to the connector on the laptop motherboard.
Yes, replacing the screen is extremely difficult, and not recommended if you have no prior experience. First check that the video adapter is properly attached. Forget about what the tech told you. I would recommend trying a different repair shop, or you can try the "Repair Service" box at the right side of this dialogue box. Just enter your zip code, and it will locate repair services in your area. This is definitely fixable.
