I have a samsung R530 laptop with internet explorer 10 and windows 7 home premium. When I print documents from the internet the print is so small I cannot read it How can i increase the size of the print?
Hello Linda,
The problem is not with the printer but with your printer settings or preferences. You have to configure the margin or layouts and then previews it first before printing.
So either go to print preview to setup the layout of what you want to print, by making your printing big depending on how you want it or you click on properties button on your printer window to setup the layout of the internet page.
I hope this has helped you.
Thank you.
SOURCE: Saving documents from the internet to 'My Documents'
It will usually do it automatically. Have you looked in all the folders in my documents? Also, if you can't get it to do it automatically, go to save as, choose my documents then click save. It should be there.
SOURCE: text size is too small on my toshiba laptop using
If you are referring to desktop font size, right click on an empty portion of your desktop, pick personalize on the context menu, and on the left side of the window, you should see "Adjust Font Size (DPI)". You can change the font size to larger scale (120 DPI) which should make the text larger. For web browsers, most should have an option to change the text size in the menu, but these steps would be different for the various web browsers available.
SOURCE: My samsung R530 windows 7 laptop product key is
The product key is only put on the bottom of the Laptop and can not be found else where.
SOURCE: VGA driver for windows 7
download the driver from here:
http://downloadmirror.intel.com/19291/a08/GFX_Vista_Win7_32_15.17.10.2189_PV_Intel.exe
SOURCE: my brother's samsung r530 wont boot up as it is
That is most likely the BIOS password, the best solution would be to ask your brother for the password so that you can boot to Windows and use it.
