SOURCE: BURN HOME VIDEO TO DVD
Assuming that your camera is not equipped to interface directly with your PC, here are the steps to take to get your videos from VHS to DVD:
- Purchase a video capture device.
A cursory websearch garnered once for $50.00 here:
ADS Tech Video Xpress
http://www.pcmag.com/article2/0,1759,1902901,00.asp
- After setting the device up, use the bundled software to convert the video file into DVD format and then burn to disc, using your favorite burnig software. Be sure that it is burning in the VIDEO_TS/AUDIO_TS format and not just copying the .avi to the DVD.
If you would like for me to elaborate on anyt of these instructions, please don't hesitate to contact me directly at [email protected]. Good luck and, again, let me know if there's anything else I can do. I think you'll be just fine though as this process is fairly straightforward...just time-consuming.
SOURCE: need manual for using the JVC GR-AX201A compact VHS camcorder
Please download user manual of GR-AX201 from JVC Support.
SOURCE: I need to transfer video from JVC GR-770U Camcorder to my compute
Hi I am Vortash according to the manual for this unit available on http://www.safemanuals.com the unit is quite capable of downloading to a computer but yes it does require the correct software to do so .. you may find this is available from JVC support as a download .. it says that you can download to a usb terminal or a Rs socket with a compatible retail software .. hope this helps Regards Vortash
SOURCE: WE NEED THE OPERATING MANUAL FOR THE JVC COMPACT
The operating manual could be downloaded from here
http://resources.jvc.com/Resources/00/00/91/LYT1519-001A.pdf
GOOD LUCK!!!!!!!!!!!!!!!!!!!!!!!!!
