You will need to give much more information. Vehicle make, model, year, engine, fuel type and what the nut or bolt is actually for. There are hundreds of nuts and bolts on any car and each one is a different torque setting. Without knowing which one your referring to you probably won't get your question answered.
Mazda Familia Parts. Browse the categories below to find the parts you are looking for. If the part you want is not in stock, fill in the request a part form and we will ...Missing: 4wd caliper
Matches 1 - 17 - Mazda - Familia - BJ5W. We supply aftermarket performance parts direct from hundreds of manufacturers in Japan, if you have a request send us ...
www.trademe.co.nz > ... > Car parts & accessories > Mazda
Trade MeMazda BT50 2009-2012 New Spot light Kit Complete. Closes in 14 ... 1990 FamiliaBG5P Chassis Ignition Barrell. Closes in 7 ... Ford/Mazda Front lower Rear Inner Bushes. Closes in 7 ... Mazda SP20 BC Gold Adjustable Suspension ~SPR ... Rx7 flywheel standard Have A S4 And S6 ... Mazda Parts ' Japanese Spares Ltd.
there may be an air lock in the cooling system
ther heater control may b not be turning on the control tap
the heater core may be blocked and not allowing coolant to circulate through it.
Check the ground wire and check for damaged wires. You can use a wire and test the bulbs with the battery. Those lights are on the trunk lid?. You may need to remove the cover for the wires and follow it and where it bends when opening may be the first place to look.
Remember you have pre loaded cam gear's that have to be loaded, or it will make kinda of a lifter noise but not lifter's. Torque step #1 17-19 ft.lbs step #2 additional 85-95 deg
