SOURCE: how to change batteries braun shaver ?
It is suppose to be rechargeable and have a 2 year waranty on it. send it bback and get a new one or just take it apart and use regular batteries.
SOURCE: Battery replacement for Braun 8585
If the "reset" described didn't work all that well, as a last resort you can replace the batteries. You have two choices: put in a battery/circuit-board part replacement (drop in), or solder in new batteries. If you've got some soldering experience, I recommend replacing just the batteries. You can buy new NiMH AA 1.2v flat top batteries rather cheaply (less than $4 per cell) and using a soldering iron, take out the old ones and secure the new ones. Look for batteries with at least a 1650mAh rating. Good luck!
Testimonial: "I believe this is a more viable solution. I will try your advice this weekend. Thanks,."
SOURCE: Braun 8585 charger cleaner - not cleaning
you can try cleaning it with alchol and see if that helps it to become unplugged and able to clean your shaver again. It may also be some contacts that is on base where it contacts the shaver. If it still does not work, you will need to replace it . Look on ebay for one to replace with.
SOURCE: Braun Drive Unit 7030244
To open the shaver, you will first need to gently pry off the 'cap. on the bottom of the shaver that surrounds the hole where the cord plugs into to. You can use a small flat screwdriver or similar object to do this. Once it is removed, the side grips will pull away revealing 4 screws on the back. Remove screws to take off the back cover. The internal parts will then simply lift out. Reassemble in reverse order.
You will find a replacement drive unit for model 8585 at shaveroutlet.com. See link below
http://shaveroutlet.com/braun-8000-series-activator-motor-drive-unit-p-36.html
Testimonial: "Fast turnaround on the response with an very easy to follow answer."
SOURCE: How do I open a Braun 8585 shaver to replace the
You will find batteries at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-battery-aa-nimh-p-108.html
To open the shaver body, you will first need to gently pry off the 'cap' on the bottom that surrounds the hole where the cord plugs in. Once removed the side grips will pull off revealing 4 screws. Remove screws to take off back cover and access insides. Inner parts simply lift out. Reassemble in reverse order
