It sounds like there may be an issue with the DAB radio's reception or configuration. Here are a few things you can try:
Make sure the DAB antenna is properly connected and positioned for optimal reception. If the antenna is not properly connected, the radio may not be able to receive any stations.
Try resetting the DAB radio to its factory settings. This may help to clear any configuration issues that are preventing the radio from properly counting stations. Check the user manual for instructions on how to reset the device.
If the above steps do not work, try moving the DAB radio to a different location in your home. Sometimes, radio reception can be affected by nearby obstacles such as walls or large metal objects.
If none of these steps work, you may want to contact the manufacturer's customer support for further assistance.
The DAB 211 FW DAB radio is a digital audio broadcasting (DAB) radio that uses a power supply to operate. The power supply is typically an external device that is plugged into an electrical outlet and connected to the radio via a power cord. The power supply provides the necessary voltage and current for the radio to function. The specific type and specifications of the power supply will vary depending on the manufacturer and model of the radio. The service manual for the 1816B Case Skid Steer will not contain information on the power supply for the DAB 211 FW DAB radio. You may contact the manufacturer or a local electronics repair shop for more information on the power supply for the DAB 211 FW DAB radio.
I suggest you scout around the neighbours for a DAB you can borrow to test the signal in your usual place. Your own radio could be faulty.
One of my DAB radios worked fine on FM even though one day it just stopped working on DAB for no apparent reason. The board to repair it is priced not to sell...
What's the make & model of the radio?
Most DAB/FM radios work from the same antenna, so if you receive FM stations, you should receive DAB stations in your area.
It should be noted that DAB transmitters work on lower power than conventional FM transmitters, and so you may be in a weak reception area (for DAB). It should also be noted that DAB uses different frequencies than regular FM stations and household appliances such as laptops,WiFi, microwave ovens, etc can affect DAb reception.
