Master:
Master
Re: Hi, I have prob with new DAB P7. He do not count dab...
It sounds like there may be an issue with the DAB radio's reception or configuration. Here are a few things you can try:
Make sure the DAB antenna is properly connected and positioned for optimal reception. If the antenna is not properly connected, the radio may not be able to receive any stations.
Try resetting the DAB radio to its factory settings. This may help to clear any configuration issues that are preventing the radio from properly counting stations. Check the user manual for instructions on how to reset the device.
If the above steps do not work, try moving the DAB radio to a different location in your home. Sometimes, radio reception can be affected by nearby obstacles such as walls or large metal objects.
If none of these steps work, you may want to contact the manufacturer's customer support for further assistance.
FM radio settings
Note: You can only see the FM radio settings when you have selected ‘FM’ as the radio source.
FM stereo option
You can choose between stereo or mono reception when listening to FM radio. Mono may improve
clarity where stereo signals are weak.
To change between Stereo or Mono reception:
1. Press the Menu button.
2. Turn and press the Select dial to choose ‘Audio Setting’.
3. Select between ‘Stereo Allowed’ or ‘Forced Mono’.
FM scan
You can choose whether your Elan E3 automatically stops at the next available FM station or the next
available FM station with a strong signal when scanning for an FM station. To change the FM scan
setting:
2. Turn and press the Select dial to choose ‘Scan Setting’.
3. Select between ‘Strong Stations Only’ or ‘All Stations’.
DAB settings
Note: You can only see the DAB settings when you have selected ‘DAB’ as the radio source.
Full scan
You can use the ‘Full Scan’ (autotune) function to automatically scan for new digital radio stations and
remove inactive ones.
To carry out an autotune:
2. Turn and press the Select dial to choose ‘Full Scan’.The number of stations found will be
displayed during the autotune.
When the autotune has finished, your Elan E3 will tune to the last station that you were listening to. If the
last station you were listening to is no longer available, your Elan E3 will tune into the first station in the
alphabetical list.
Manual tuning
To manually check the signal strength of a known channel:
2. Turn and press the Select dial to choose ‘Manual tune’.
3. Turn and press the Select dial to choose the channels.
I suggest you scout around the neighbours for a DAB you can borrow to test the signal in your usual place. Your own radio could be faulty.
One of my DAB radios worked fine on FM even though one day it just stopped working on DAB for no apparent reason. The board to repair it is priced not to sell...
What's the make & model of the radio?
Most DAB/FM radios work from the same antenna, so if you receive FM stations, you should receive DAB stations in your area.
It should be noted that DAB transmitters work on lower power than conventional FM transmitters, and so you may be in a weak reception area (for DAB). It should also be noted that DAB uses different frequencies than regular FM stations and household appliances such as laptops,WiFi, microwave ovens, etc can affect DAb reception.
Hi, Thanks for writing to Fixya.com. Although the DAB signals are less prone to interference, they're currently weaker than FM signals, which can cause problems if you're in a fringe reception area .Please check into this. Moreover DAB radio stations are "compressed", so that lots of stations can be squeezed into the available bandwidth. Because of this compression, some stations on DAB are not in as good a quality and you are getting repetition issues. Thanks for contacting Fixya and please accept the solution if it has helped you.
