SOURCE: I have a magic chef freezer that is not keeping
i have a magic chef freezer that is not getting cold
SOURCE: what shoud I set my magic chef deep freezer at
It should be set between 10 and 20 degrees Fahrenheit
SOURCE: from 0 to 9 what is the coldest setting for my
9 is usuly the coldes setting on the freezer. It needs 24 hrs to get to the setting that you put it on.
Good Luck and please rate 4 thumbs up for the free answer
SOURCE: magic chef portable freezer not cooling.
first of all are you sure its running correctly,if its overly hot to the touch is may sound like its running which it may be,but only on the start/run windings and if left this way it will burn out soon,it needs start/run windings to oppose the pressures inside the compressor to get it up to correct operating speeds,then the start winding cuts out of the circuit,this is where the ptc overload comes into play,as it does this sequence switching to make it operate correctly,just unplug it from the compressor and plug in a new one,also you may think you hear the compressor running,but its only the fans in the unit running,a compressor will run warm but shouldn't be overly hot to the touch,then if this isn't your problem,it could be an evaporator core blocked by ice and you cant get cold thru a solid block of ice so iuf its a self defrost model the defrost thermostat or defrost heater might be inopertive too
