My kenmore elite Model 795.71069.011 measure starts at .34 oz instead of zero oz. Is there a way to reset or re calibrate the measure fill feature? Thank you!
SOURCE: Kenmore Dishwasher won't fill
Not likely an air lock. When plumbing work is done the pipes ge shook up and then particles plug up the screens on these and washer and faucets. I would make sure the over flow float is properly working and then check the screen on the fill valve. Could be a coincidence and the valve failed but that is my last choice in this case. Eric
SOURCE: My new Kenneth Cole kc3730 wristwatch when I use
If it is a new watch then have you still got the user manual?
I have seen some watch instructions detailing how to do want you want to do, so it might be a common problem.
If you cannot sort it out and have a Kenneth Cole dealer near you, then take it in and discuss it with them.
Their web site does not seem to have any instruction manuals for downloading , so I can't read the instructions for myself but if phone them on 1 800 KEN COLE (536-26530), then they may be able to help you.
SOURCE: Kenmore front-loading washer water fill up when not in use
The problem is commonly attributed to either a leaking water inlet valve, or a pressure switch malfunction. The following link explains how to diagnose and repair the problem yourself:
http://www.fixya.com/support/r3753262-front_load_washer_fills_when_not_in_use
I've included steps on how to replace any defective parts and parts resources if you need to order anything. If you have any questions, please let me know. I hope this helps you.
Testimonial: "It gave me a very good direction, just haven't finished it. As you said it may be helpful, the washer mode# 110.44932201. Thank you very much!"
SOURCE: kenmore catalyst elite washer fills but does not
the reset is to unplug the washer for 5 minutes, if that doesn't reset it u may have a defective motor controller circuit board
