Dishwashers Logo
Question about Dishwashers
Kenmore Elite Dishwasher won't start and beeps 15 times instead
When trying to start my dishwasher it won't start and beeps 15 times instead. Please help.
Posted by Holly Bustle on
ADMIN Andrew
    Top Expert:
  • Dishwashers Master
  • 57,371 Answers
Posted on Jan 10, 2022
I have a Kenmore Elite Dishwasher. My control lock will not stay off.
Question edited to what I think you thought you were saying.
Question moved from 'Elite Office Equipment'.
Did you press and hold the buttons?
How to Turn Off the Lock Mode on Kenmore Dishwashers
  1. Press the "Heated Dry" or "Air Dry" button on the control panel for four seconds until the Lock button lights up with a solid light. ...
  2. Note that any button that you press while the machine is in Lock mode flashes four times.
More items...
More here
https://www.google.com/search?q=kenmore+elite+dishwasher+how+to+remove+Control+Lock
Kenmore elite dishwasher manual
The cancel light is on because the cycle maybe paused or canceled. The lit red button should say Cancel/Drain. If you already tried to press start and if it won't finish the cycle then try pressing the Cancel/Drain to drain and start over.
My Kenmore Elite Ultra Wash Dishwasher keeps shutting off before entering the cycle. I have repositioned dishes, even emptied it, changed cycle and tried everything. When I press the start light flashes...
I too had problems with the Kenmore Elite (aka Bosch). The issue was solved by replacing the Lock Sensor on the door. After replacing the sensor the dishwasher has been working. Hope this helps.
I pressed the NORMAL CYCLE then I pressed CONTROL LOCK (3 SECONDS) Pressed START It will not start
Hi
First make sure that nothing is blocking the drain pump assembly located inside the lower front panel of the dishwasher. If the issue returns after its cleaned then try to reset the dishwasher control by pressing the HEATED DRY button and hold it for 15 seconds, if its still not resolved then it means that the control board has gone bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
6helpful
2answers
Kenmore Elite Dishwasher Problem
I had this same problem so I took the front panel off to access the thermal fuse.  What I found instead was that food had become lodged in the door latch which was keeping the door safety switch from operating properly.  I took a thin screwdriver and removed the food from the cavity.  Since you did not have the problem in your first five years the cavity just might be the problem since that is about the amount of time it took me to get too much food stuck in mine as well. This solution took five seconds and requires no disassembly.
Oct 09, 2008 • Dishwashers
Open Questions:
0answers
Bosch dishwasher lights turn off when running, but are on again when door opens SHV46C03UC/21 I replaced the control board with new OEM board last week, because heater relay was blown. Dishwasher now works fine and runs normal length of time. For this family of dishwashers, the buttons and red lights are on top of the door Bosch SHV46C family; full model name shown above. A thing I noticed is that the red wash indicator lights now turn off when I close the door and start DW running. When finished, no lights are on either. BUT, when I open the door at end the proper lights turn on again indicating dishes are clean and cycle that was selected. So, indicator lights are correct except they all turn off when DW running and door closed. With the original board, the indicator lights would stay on when running and I could see them. 1. Is this some change to the latest board that I just have to learn to live with? This DW was made ~19 years ago. 2. Or, is there a way I needed to program the replacement control board I installed to this specific model? Regarding #2, I'm asking this because I have read that some control boards need to be programmed to the certain Bosch model, but I'm not sure if this one needs it. I ran test mode for original and new board, and I think this new board passed because it did not show any error code with a solid indicator light, though one indicator light was flashing which I think just meant it was still in test mode until I powered it off. Thanks, Chris
Top Dishwashers Experts
Marvin
Marvin
mark warfield
mark warfield
