Iview 900TPC 9" Tablet Logo
t
thomas dean Posted on May 07, 2014
Iview 754tpcii suprapad 1gb hard factory reset
Turns on but screen stays black tried the cyber pad method but does not work need help
1 Related Answer
MotoManiac
  • 13 Answers
  • Posted on May 07, 2014
SOURCE: how to factory reset a iview suprapad 7" 1gb tablet
press FACTORY RESET button in settings
2answers
How do i reset my asus transformer tablet tf101 i have a blank screen will not turn on
Perform a soft or hard reset on your Asus Eee Pad Transformer Android tablet if it is not functioning correctly. Here's how.
Soft Reset
You would want to soft reset the device in the event that it has become frozen or unresponsive. To do so, press and hold the Power button on the top-left side of the device for about 10 seconds until the device powers off.
Hard Reset
A hard reset (also known as a factory reset) will clear all data and settings from the memory of the device and set it back to factory default settings. You can perform hard reset on the Asus Eee Pad using the Android OS menus or the hardware buttons.
Method 1 1. Power the Eee Pad off.
2. Press and hold the Volume Down button on the left side of the device, then press and hold the Power button.
3. Continue to hold both buttons until a bootloader screen appears.
4. Wait for the prompt that says to "Press <VOL_UP>" then press the Volume Up button to start the process.
The Asus Eee Pad will complete the hard reset process and reboot into a factory default state.
Method 2 1. Open the Settings app.
2. Select Privacy.
3. Choose Factory data reset.
4. Select Erase tablet.
5. Select Erase everything.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/dave_fb2c45146b845cea
1helpful
Factory reset
Most tablets you hold in the volume up and power button for 5-15 seconds and logo should appear asking to reset.
Pattern unlock android
do a factory reset most of the time this works it take it back to the orignal state when you bought it
it should up load all the needed files to restart it with out ant troubles
Top Iview Tablets & eReaders Experts
 Mikey
Mikey
ADMIN Eric
ADMIN Eric
Are you an Iview Tablet and eReader Expert? Answer questions, earn points and help others
