Ask to turn on my Bluetooth device well infact its built in in my Acer Aspire 4710. Please help how to turn on or install hardware if no device. thanks
1. there will be switch for blue tooth 2. may be switch off, turn it on 3. otherwise, download free bluesleil bluetooth software,hope your bluetooth will work.
Go to my computer, right click, properties, advanced or advanced system settings, hardware, device manager. Now look for your bluetooth device, if it is not listed it needs a driver, which can be found
on acer's support site, or if you know the manufacture, you can go on their website and get it. I hope this helped solved your problem.
This computer does not have Bluetooth capabilities and you can't make it, by adding a Bluetooth Driver. It would need a Bluetooth transmitter and receiver HARDWARE built into the computer at the time of manufacture..
Probably your laptop dosen't have bluetooth hardware in it. Confirm it by following process Right click on My computer and click Manage then click on device manager on left panel A list will appear which shows the hardware content of your laptop. If the list dosen't contain bluetooth device then it is confirmed that your laptop dosent have bluetooth hardware. Try using external USB bluetooth device for your laptop. Cost couple of dollars.
Hi there, please follow the instruction.
1. turn off Bluetooth button.
2. run your Acer driver disk & install the Bluetooth
device. After a while your laptop asking you for turn
on your Bluetooth. Press the button of Bluetooth. It
will installing then. After a while another message
will come in front of you that, Bluetooth device
installed & ready for you.
You may also watch the link for some an idea about setup a Bluetooth.
if you have in on your laptop you have to get the software for the
bluetooth then you must install it on your laptop then it will be done ,
if you don't have that CD you can downloaded from the technical support
for ACER.pan am
The 4730Z does not have bluetooth onboard. The bluetooth button is there because the 4930,model shares the case and some hardware with your 4730Z. hardware
with the 4930 which does have bluetooth. You will need to add an internal
bluetooth device or USB bluetooth dongle if you want bluetooth.
could be that your acer aspire 3680 actually doesn't have bluetooth. they use a standard case for most of there laptops. it has the button for bluetooth but it doesn't have the actual bluetooth card or required hardware.
Set up a Bluetooth enabled deviceTo set up a Bluetooth enabled device, you need to do three things:
Add a Bluetooth adapter to your computer. This is usually done by plugging the adapter into a USB port. (If a Bluetooth adapter is already built in or attached to your computer, ignore this step.)
Set up the device so that your computer can find it. To do this, you must:
Turn the device on.
Make it discoverable.
To learn how to make a device discoverable, check the information that came with your device or go to the manufacturer’s website.
Install the device. To install most devices, such as a mobile phone, keyboard, mouse, or personal digital assistant (PDA), you can use Bluetooth Devices in Control Panel. If you have Bluetooth wireless technology installed on your computer, follow these steps:
To install a Bluetooth enabled device
Click the Start button , click Control Panel, click Hardware and Sound, and then click Bluetooth Devices.
