I finished my search and want out of program
Try exiting normally using the X button on top right hand of screen. If this does not work Type and Hold: CTRL + ALT + DEL on your keyboard at the same time.
If running Windows 8 or 7 select Task Manager. Any other OS will likely pull up task manager automatically. Select the offending program from the list of open programs and close it.
Depending on how locked up the program is this may take a moment. If after a full minute or two this still fails, you may need to use the same option to pull up task manager and reset the PC.
Most of the spyware programs on the Internet that will infect your computer log the websites you visit so that they can launch pop-ups and advertise products for you to buy.
If you have recurring pop-ups caused by spyware that appear whenever you connect to the Internet, you will need to completely remove the spyware causing the problem.
The most effective way to remove all spyware from your machine is to use at least two different antispyware programs while your computer is in safe mode so that the spyware cannot open itself.
Navigate your web browser to a website that offers a spyware removal utility such as "Spybot" or "Lavasoft Adaware".
http://www.safer-networking.org/index2.html spybot
http://www.lavasoft.com/ lavasoft
Download and install the antispyware software.
Navigate to a second website and download a secondary antispyware utility.
Restart your computer and wait for the manufacturer's logo to appear on the screen.
Press the "F8" key repeatedly until a new menu pops up.
Scroll down through the list of options and highlight the entry labeled as "Safe Mode."
Open up the first spyware utility you installed earlier once the operating system has finished loading in safe mode.
Click on the antispyware utility's "Update Now" button at the left side of the window.
Wait for the program to finish downloading the latest spyware detection routines.
Disconnect your computer from its Internet connection either by unplugging its Ethernet cable or by powering off your wireless router.
Click on the "Search For Problems" button above the "Update Now" button.
Wait for the program to finish scanning your computer's hard drive for spyware, and then click on the "Remove Selected Problems" button.
Close down the antispyware program.
Reconnect your computer to its Internet connection.
Open the second antispyware utility you downloaded earlier.
Run the program's update feature and then disconnect your computer from the Internet again.
Run the program's scan, and then remove any problems it finds.
Reconnect your Internet connection and then restart your computer to finish removing the recurring spyware pop-ups from your PC.
Hope this helps
After you have finished connecting your TV, you can use Auto Program to set up your
channels. During Auto Program, the TV will automatically search for available channels and
program receivable channels.
[1] Press POWER button on the TV to turn it on. The Initial Setup screen appears.
[2] Press CH+ button on the remote control or on the TV front panel to start Auto Program, or press CH-- button to exit.
The Initial Setup screen appears each time you turn on the TV until you perform Auto Program.
To perform Auto Program again
1 Press"MENU" button on the front panel of your TV.
2 Press "RIGHT ARROW button to highlight Channel Menu.
2 Press DOWN ARROW BUTTON to highlight CABLE or ANTENNA AND PRESS [+} to select.
4 Press UP arrow or DOWN arrow to highlight On or Off according to how you connected your TV. Press [+] to select.
4 Press F or f to highlight On or Off according to how you connected your TV. Press to
select
5 Press DOWN arrow button to highlight Auto Program. Press [+]to search for channels
6 After Auto Program finishes, press MENU button to exit.
OK
