iPhone Apps Logo
Angie Barbour Posted on Apr 25, 2014
My kobo wont turn on
It wont turn on i have done the basicis the light comes on saying its on but the screen is blank
gjbrian
Level 1:
New Friend:
Problem Solver:
  • Contributor 11 Answers
  • Posted on May 09, 2014
gjbrian
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
11
Questions
0
Helped
2746
Points
16
When you slide the switch back, you should wait 3 sec and then let it go the green light will come on - if screen stays blank re- syncing you e-reader to your computor.
1helpful
Kobo Touch has a white screen and not responding to anything. Tried turning on and off light goes blue and then back to green. Same thing when I tried a reset. Has it died? It's 5 years old
My Kobo Glo had similar problems.
It did not switch off anymore. I left it overnight and the next morning it showed a screen with some error picture.
I did a factory reset using the light-button and the on/off switch simultaneously. This procedure differs per Kobo-version. After that a screen opens to select a language. Then you can select if you want to proceed using a computer-connection or using WIFI. Selecting wifi I was able to connect to my internet, but shortly afterwards i received a message that something went wrong with the connection.
So I reset again and tried again, now using the computer-connection. Following the info on the Reader-screen and using kobosetup.exe on the computer started a factoryreset which took a long time. Alas ... after the loading of the latest firmware ended, the restart of the Kobo Glo got stuck and ended with a black screen that looked like a broken screen.
Next i did a new factory-reset, used the computer-connection-option which enabled access in NOTEPAD to the internal memory of the Kobo.
I downloaded the latest firmware for my Kobo-glo:
kobo-update-4.31.19086.zip
and extracted the zip in the map
.kobo
of the internal kobo-memeory
Now, after removing te usb-connection with the computer the new firmware starts loading, but .....
alas the same broken screen as a result.
Was there a problem with this latest firmware-version???
Yes! it seems so!
Repeating the latest reset-procedure, now with an older firware-version:
kobo-update-4.17.13694.zip
resulted after disconnecting from the computer in a WORKING KOBO GLO again.
However you have to reload the books since they were deleted during the reset-operation
Bert Spronck (NL)
Kobo won't turn on
https://koboproblems.wordpress.com/2013/07/15/how-to-reset-and-factory-reset-your-kobo/comment-page-1/?hc_location=ufi
you have looked how to reset your device
you may loose all settings but im sure it has a cloud backup as most do
good luck
other than this perhaps try to wait till it powers off from very low
bat
i found a few links to forums
google search for links
kobo reset
or factory reset
My Kobo Aura HD's comfort light is off and I can't find a way to turn it back on.
On the top of the e-reader, to the left of the on/off slider (looking at the screen) there is a push button on/off switch for the light. Once the light is turned on (and there is a 'star' symbol on the screen, the brightness can be adjusted by touching the 'star' and using your finger to slide the brightness control).
Kobo won't turn on, screen blank
This can happen if the battery is very, very flat. Try charging it overnight.
If charging it doesn't help, try using a paper clip in the reset hole to force a factory reset (you may lose any user-installed books).
1helpful
Kobo ereader fell on floor just have a blank screen
the lcd backlight called a CCFL tube much like the stip lights
has becomes disjointed or has cracked
if the screen survived uncracked then its worth getting it looked at by someone who knows LCDCCFL and where to gain a replacement
Kobo mini screen images stuck in one corner
From what you say I would recommend a new unit
Try this, it worked for me
Turn off phone
Remove battery
Wait 10 seconds
Plug in charger
Insert battery
Turn on phone
Dec 12, 2017 • iPhone Apps
3helpful
My touch screen kobo reader has stopped working
Make sure the Kobo is fully charged and switched off. Hold down the 'HOME' key while turning the Kobo on. When you see the power light release the 'HOME' key. The lights will flash. Follow the onscreen prompts.
Top Apps Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you an App Expert? Answer questions, earn points and help others
