20 Most Recent
Kobo eBooks by Kobo Questions & Answers
Screen is frozen device will not turn on
You can do a hard reset by holding down the round home button on the front, and the silver power button on the top, hold down both these buttons until you see an apple, then release both. Do this while unplugged
Kobo support
I take it you are first going in to Kobo and then plugging in your e-reader, if it does not start to sync click on the button (top right) and it should sync - if this does not help - delete disk top and re-load
Good luck
How do i download books onto my kobo ereader
You should have first of all downloaded Kobo desk top apps on to your computer - after which you can buy book....then syncing ...once the book has been loaded to your library you plug your e-reader in and syncing, this loads the book on to your e-reader..
Good luck
My touch screen kobo reader has stopped working
Make sure the Kobo is fully charged and switched off. Hold down the 'HOME' key while turning the Kobo on. When you see the power light release the 'HOME' key. The lights will flash. Follow the onscreen prompts.
How to restore deleted ebooks
Hi, there. As a matter of fact, every time you sync data between iPhone and iTunes,
all previous data will be automatically backed up by iTunes and stored
as a .sqlitedb file, which will be updated along with the later sync
continuously. But those backup files can't be viewed or taken out unless
you use some software using special algorithms to extract. Learn
how to recover your iPhone eBooks with step by step guides.Regards!
My kobo reader will not
Since you have purchased the book and it's not working or refuse to sync, then it means its not compatible. SI would advice you ask for a refund or ask the site to give you a book that would be compatible.
To contact the owners of the website for a refund, check the top of down part of the site, you will find "Contact Us". Click the contact us and you will find a e-mail address and phone number. Contact the site and they should either refund your money or give you a book that would be compatible.
I hope you understand the above..
Good luck.
My screen on my kobo
You will most likely need to buy a new one. I looked online for a replacement screen and I could not find one.
How do I delete kobo
Go to the library screen and tap the button on the far right top corner. This will make your books into a list. To delete a book, simply slide your finger from right to left and hit the red delete button that appears.
How can I load a movie in iPhone from my pc
easiest way is to load the movie file into Itunes. Then under menu: Advanced is a button to convert movie to IPOD.....
click it
u'll se a converting area appear around where itunes has its devices or store downloads.
once its done converting, make sure ur Iphone sync has movies checked, and select that movie
2/11/2024 10:24:23 AM •
iPhone Apps
Answered
on Feb 11, 2024
Whatsapp code
Try it one more time in a better network area. You should def get the code in less than an hour. If you dont there is a problem in registration of your number/device. Hope this helps.
9/11/2023 10:47:23 AM •
iPhone Apps
Answered
on Sep 11, 2023
