2003 Jeep Grand Cherokee Logo
D
Daniel Nikolov Posted on Apr 24, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
OBD p1242 ,p0703,p0702 grand cheeroci
Help
steve
Level 3:
  • Jeep Master 3,718 Answers
  • Posted on Apr 24, 2014
 steve
Jeep Master
Level 3:
Answers
3718
Questions
Helped
964519
Points
12533
Ok so 1242 is sensor power supply high input ,0703 is detected de-acceleration with no brake switch activity and 0702 is fault with trans control unit i'd guess your having running/accelerating problems ,have the codes wiped and road test and see if problems continue if they do i'd get the ECU checked out as a first step
2010 Suzuki Kizashi SE 2.4. I recently replaced the motor and ECM. It will crank but won't start, I have 3 codes P062f, P0703, and U0100.
Question edited for clarity
The ECM and the engine need to be from the same vehicle and then the ECM needs programming with your VIN Number and your mileage.
Code U0100 What Does the U0100 Code Mean? DTC U0100 stands for "Lost Communication with ECM/PCM 'A. '" It is triggered once there is a loss of communication between your PCM and a particular module. Once this happens, the vehicle may shut off and it may not restart unless you address the issue triggering the code.May 2, 2021
U0100 Code: Lost Communication with ECM/PCM "A"
https://www.carparts.com > blog > u0100-code-lost-comm...
Search for:
Code u0100
P062f - generic PCM eprom code, means the pcm either has an internal fault, or its internal memory is well and truly scrambled.
https://www.google.com/search?q=2010+Suzuki+Kizashi+SE+P062f
P0703
P0703 OBD-II Trouble Code: Torque Converter/Brake Switch ...
https://www.yourmechanic.com > Articles
P0703 Code means the PCM has registered a fault in the brake switch B circuit due to failed brake lamp switch, faulty fuse or socket.
I have a Jeep Grand cherokee 2002. The gears have gone into limp mode. i am getting the following error codes: P0703, P0403, P0702, P1130, P2125, P0700, P0579. I am guessing there is a electrical box gone...
no engine options stated, now THAT is a challenge, x100.
4.0L or 4.7L?? 3.1L, 2.7L AND 4.7HO (EXPORT)
ASKING WITH OUT ENGINE TYPE IS HOPELESS. !!!
i Just wing it, and try to guess.
this is not the Diesel engine , right? is this a USA car or export?
this is a USA site so we must ask that. (nobody does but...must)
the FSM covers this, the factory service manual.
45RFE and 545RFE automatic transmission
the p07 are all transmission errors from the TCM brain.
p04xx is EGR, failure, so skip that. for now.
a/t limp means the TCM , see's gross errors. why it does, takes TESTING. by a technician,
not Gue$$ing, .
here is book for 2002. (USA only, ok ?)
http://www.jeep4x4center.com/knowledge-base/index.htm?utm_source=cj#service
see emission page for all DTCs.
700, 702 and 703
702 is not listed, is that a non USA market engine?
i see lots of posts on 702 or Diesel , why is that? and missing in the gas, FSM i have. ??????
700 means ,Ive got tranny errors see others for why.
703 is brake lamp stuck on failure.
579 --
Cruise control system inoperative 1130
P1130 Oxygen Sensor Circuit Low Variance (Bank 1, Sensor 1)
my guess is this is the first scan in 10 years. and all those codes
are antique? reset the PCM and drive and see the codes that
are real for NOW.
(all cars do that after writing them all down as you did)
2125 (not in my usa FSM oddly)
but googling finds one diesel here.
Throttle/Pedal Position Sensor/Switch "E" Circuit
that is all i can do , with
NO COUNTRY STATED
NOR which of 5 ENGINES USED .
sorry !
Transmission troubleshooting
p0340 cam shaft position sensor malfunction,P0700 Transmission Control System Malfunction, P0703 Torque Converter/Brake Switch B Circuit Malfunction,
P1652 P 1 6 5 2 OBD-II Diagnostic Powertrain (P) Trouble Code For Engine Fuel And Air Metering O2 Sensor Heater Circuit Malfunction Turbocharger Boost Sensor A Circuit Low Crankshaft Position Sensor A Circuit Low Input
2000n vw beetle wont go more than 30 mph
You're in LIMP MODE, the system is preventing any further damage to your car by limiting the speed insisting that you see a service center ASAP.
I see a P0702
17086/P0702/001794 Contents [hide] 17086/P0702/001794 - Transm. Control Module Electrical Malf. (SAE) or Control Module Defective (VAG) Possible Symptoms
  • Malfunction Indicator Light (MIL) active
Possible Causes
  • Control Module faulty
Possible Solutions
  • Replace Control Module
Cherokee crd p1242
need somebody to explain me,how to repair my jeep grand cherokee that this default code P1242. The is heavy, diffcult to move forward, after using the drb3 i found this dtc in pcm system and transmission system.
many thanks!
Fault code p0703
P0730 Incorrect Gear Ratio
P0620 Generator Control Circuit Malfunction
P1130 Not found
P0340 Camshaft Position Sensor Circuit Malfunction
1helpful
Fault code p0702
P0702 Transmission control system electrical
1helpful
Good afternoon, I have a Grand Cherokee 2002 and the problem codes are : P0702 P0836 P2310 P240D . Can you please help me to find out what is going on, because in my area at the service they don't...
CODE PO702 TRANSMISSION CONTROL SYSTEM ELECTRICAL.POSSIBLE CAUSE WIRING OR TCM. / CODE PO836 FOUR WHEEL DRIVE SWITCH CIRCUIT MALFUNCTION. / CODE P2310 IGNITION COIL D PRIMARY CIRCUIT, CIRCUIT HIGH, INJECTOR CYLINDER 1 IMPLAUSIBLE SIGNAL./ CODE P240D MANIFOLD ABSOLUTE PRESSURE SENSOR B, TC SYSTEM RANGE PERFORMANCE PROBLEM.POSSIBLE CAUSE INTAKE EXHAUST LEAK,HOSE CONNECTIONS MAP SENSOR FAULTY. HAVING TOO MANY CODES COULD BE FAULTY PCM.
I have a GC 2.7. 2002 I'v a problem with P0702 P0703 together, it's happened with a strange noise to the trasmission,; I've switched off the motor and after I ve had no more problem, but the...
Hello my friend from Italy. I have exactly the same problem. Since it happened to you 1 year ago, I hope you solved the problem. Can you tell me what was the solution. Please write to me at: 7_19_2012_10_20_28_pm.png. Thx
5helpful
I have a P0702 transmision trouble diagnostic.how
Transmission Control System Electrical=P0702 code,
Have you talked to a jeep dealer yet,
Ask if there are any TSB's on this problem.
Technical Service Bulletins from Jeep when they find and solve different complaints.
What ever is doing this is a soft code,A soft code is one that will clear it's self with the cycle of the key to off then on and code goes away,But have them check history codes to see if it is there.it sounds like it is going into limp mode,this feature is when the computer sees a transmission falt it wont up shift,so you don't harm the tranny,but will let you limp to a shop to get repaired.have you ever noticed the speedometer going to 0 then this happens?
that would be the output sensor.
Top Jeep Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you a Jeep Expert? Answer questions, earn points and help others
