I just recieved an asko 6903 today. I washed one load and all was well. Next load, though, I set it on automatic and now i recieve overflow fault and there is no way terminate the cycle. I tried the start stop button numerous times and for umptin seconds... I can only turn the power off and on turning it on, it resumes draining as it has for the last 2 hours... there is no water in the machine! It continues to drain even when i open the door with the special key... what am i doing wrong? or will this be lemon no. 5 from asko?
SOURCE: Asko Front Load Washer major water overflow from powder dispenser
You may have the hose between the dispenser and bowl blocked
SOURCE: Asko Frontload wont stop running water
you need a new inlet valve take off the top panel then you see the inlet valve follow the inlet hose
SOURCE: Asko W6461 - will not drain
is the pump comming on look inside the pump with a tourch there may be somthing stuck behind the impeller
SOURCE: machine wont stop filling with
Same thing happened to my ASKO W600. Sounds like the water inlet valve is blocked or broken so therefore can't stop the flow of water coming into machine. Check it out and replace if necessary.
