If you mean delete a user account, go to control panel
find User Accounts and, well delete whomever.
Just be sure you are the Administrator of the computer.
Other wise no go.
You can try to reset the device by pressing the power button for about 15 to 20 seconds..if that doesnt work I would recommend you to go to the sandisk site to update the firmware on your device or you can contact sandisk to they can help you with updating the firmware on your device..Please follow the link below to get the firmware http://www.sandisk.com/Retail/Default.aspx?CatID=1376
The number for sandisk is 1-866-726-3475 Please rate accordingly Thank you Computerrep
Your post does not mention all IP addresses in use, and which devices use wireless. That information would be helpful.
Is it possible that you are getting an IP address from a router for your internet access, then when you try to talk to your print server it may be trying to assign an ip address too.
(Sometimes a wired computer also has wireless enabled, which can cause an issue when one ip address has already been received on the wired connection and a wireless connection is also trying to connect.)
Windows is absoulty notorious in glitching any time it takes a notion. There is software out there that will prevent about 80% of it too. ( freebees ) I suggest first step go to add/remove programs, dleate the program for it ( software ) and re load it. Generally this cures probleums like re-booting your computer. If it's afeeding probleum, then the rollers need to be cleaned. I use denatured achol and quality "Q" tips. If printing is the probleum, the ports in the tank feeds ecome clogged from time to time too. Same senerio there-denaturd achol and quality "Q" tips.Denatured achol doese not leave behind any resedue like other types. If after all this it still doesn't co-operate, then replacement is in order. ( if warentee is deleated ) Dancer
