Sony Bravia KDL-40S4100 40 in. LCD TV Logo
Barbara Thring Posted on Apr 20, 2014
Can't adjust the screen size.
How can I fix the screen size on my Sony KDL 40S4100? The heads of people are cut off at the top.
Carl Peters
Level 1:
Habit-Forming:
New Friend:
  • Contributor 26 Answers
  • Posted on Apr 21, 2014
Carl Peters
Contributor
Level 1:
Habit-Forming:
New Friend:
Answers
26
Questions
16
Helped
6682
Points
54
The size is adjusted by checking you screen size it is in your menu if not, then you will ned to have it serviced,.
Jim W.
Level 1:
New Friend:
  • Contributor 12 Answers
Jim W.
Contributor
Level 1:
New Friend:
Answers
12
Questions
0
Helped
1939
Points
24
If you are using DirecTV with this set make sure your format is set to original format. Otherwise just make sure in the video settings you are set to original format. It is probably set to crop format now.
5 Related Answers
Coldcut
Karl Whisenand
  • 1554 Answers
  • Posted on Feb 18, 2008
SOURCE: cannot fill screen with normal picture size setting
assuming you all have comcast and using an hdmi cable
first access menu (hit it twice) and go to set picture format, choose passthrough....or in your case auto hdmi
then turn box off, press guide and info on the front of the box, proceed through the setup, advanced is more in depth..lol...
select 1080, 720, and then either the standard or widescreen 480s to your liking.....
voila....
now check your tv settings to accommodate
Anonymous
  • 187 Answers
  • Posted on Jun 06, 2009
SOURCE: i have a sony bravia model # kdl-40s4100 40 in
If you have the led light on, then you need to replace the mainboard.
If no led light then replace the powerboard.
Anonymous
  • 1077 Answers
  • Posted on Jun 28, 2009
SOURCE: MY SONY KDL-40S4100 IS ON STAND BY AND THE RED
The most likely the TV has a power supply related problem. The most common thing to go out is the circuit board that supply power to the screen. Commonly called a Backlight Inverter Board.
I can't say it's 100% the problem because I can't actually look at the tv over the internet.
If by chance the TV is still under warranty, go that route.
If not under warranty and If you have some electronic experience, you can purchase a Service Manual over the internet and diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, test points, and part# lists. Usually, cost under $20.
I hope I shed some light on the subject for you.
Anonymous
  • 157 Answers
  • Posted on Nov 09, 2009
SOURCE: My Bravia KDL-40S4100 lost all 3 of it's HDMI
There is a problem with the processor. The only way to resolve this issue is to replace the main board. It is called the A board in your TV.
There are two for this model and the correct one will depend on what your serial number is.
Part numbers are as follows:
part # 185709211 for Serial #
1,000,001 - 1,350,000
1,700,001 - 1,750,000
1,800,001 - 1,804,270
1,804,271 - 1,818,372
1,818,373 - 1,830,000
list price: $504.87 core charge: $680.00
part # 185709231 for all other serial numbers
list price: $505.87 core charge: $600.00
Testimonial: "Thanks, Now I wonder who all shares the same problem and if Sony is willing to do something about their defective products..."
Anonymous
  • 51 Answers
  • Posted on Dec 15, 2009
SOURCE: I have a 42" Sony Bravia KDL-40S4100
Probable power supply
Sony bravia KDL 40S4100 No picture
If you wish to get some details; check the site linked here. Pull up older posts.
Troubleshooting procedure for No-Picture is given in detail.
1helpful
KDL-40s4100 power light on, black screen
Main PCB is bad . I just got the information from a Sony authorize servicer price for the part only $504.87
Black screen w/ my sony bravia KDL-40V4100 and it will turn on, but there is no picture or sound. I was told it could be a possible issue w/ the kdl 40s4100 board, but I'm not entirely sure. I've...
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Hello, This Sony KDL 40S4100 is only recieve NTSC signal, is there is any firmware or anyway that I can make it recieve PAL signal??? Thanks for your help.
This is another Sony KDL 40S4100
Anybody out there?
4helpful
2answers
Picture too large for screen
Press "wide mode" on TV remote until it is on "full". Check for same on set-top box.
2helpful
Sony Bravia KDL - 40S4100 LCD needs new LCD Screen. Where Do I find one?
You do know that the screen alone will cost you approx. 75% or more of the price of a new TV don't you? Good luck !
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
