SOURCE: sony mhc-gx450 cd player is not reading.I used a cd cleaner and d
First unplug the unit and press the power button to make sure all the power is out of the unit. Try to take a cotton qtip and clean the lazer lense with alcohol. after wipe it clean with a new cotton qtip to remove the film the alcohol produces. Do not use a lot of alcohol and drip it all inside of the unit though.
Also if you tried a cd-r try a real copy instead. Make sure your cd's are ok.
Good luck.
SOURCE: I have the sony mhc-gx450 and my CD player is
Most probably there can be two kind of issues (there is not enough data about symptoms) :
-either the lens is dirty / dusty : clean it with a special CD and cleaning product (the easiest, it doesn't require you to disassemble the player). If you are meticullous you can also clean it with ear-cleaner and a drop of windows cleaning product (you need to dismantle the player)
-or the drive belt is cut or loosen : change it for a new one (be careful : a new belt can seem REALLY short because it has to be tense almost to its maximum. If you use a wrong belt -a bit too long- it will slip). symptoms : the drive doesn't fully eject (or at all), or the drawer can't completly get back. The motor can't mount inside the CD hole.
SOURCE: CD player is not working of sony model MHC-VX501
From your description it is the pladder motor that is not turning, keep in mind if the laser is not working properly that can mask the symptom. To get a service manual you will need to contact Sony"s customer support and the technical department to see if they can provide with what you need.
