Unlees you have had a loss of gear oil this is unusual.
I would first remove the linkage on the gearbox and see i i could manually move the shifter. Obviously, if i could, then the fault is in the shift rods or lever.
If the gear shift on the bix is jammed, the box will gave to come out for strip down and inspect or get another gearbox.
Cheers
Roger
SOURCE: The gear shift get's stuck
Could be the shifter interlock switch - your car requires that the brake pedal is pressed before it can come out of park. If that switch is not working, the car won't ever know you're pressing the brake, and won't let the car out of park.
SOURCE: gear lever stuck on '96 Toyota Lucida Estima
Put your foot on the brake and you will be able to move the stick...
SOURCE: I have a Toyota Corolla AE 100 manual gear shift gets stuck
why my 2006 corolla car gearbox is stuck in third gear and cannot move
SOURCE: 2003 Toyota Camry drivers side power seat stuck
This is not necessary...as many have stated...use a hammer with switch in reverse position. Hammer the seat back...it will catch...
