1998 Chevrolet Camaro Logo
m
mayhemschaos Posted on Apr 16, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Wondering how much power
How much horsepower is at the back tires? 2013 Camaro 2SS automatic 6 speed without any mods
Johnathan Lence
Level 3:
Master:
  • Chevrolet Master 443 Answers
  • Posted on Apr 16, 2014
Johnathan Lence
Chevrolet Master
Level 3:
Master:
Answers
443
Questions
Helped
171131
Points
1226
Gas Mileage16 mpg City/24 mpg Hwy
EngineGas V8, 6.2L
EPA ClassCompact
Style NameCoupe 2SS
DrivetrainRear Wheel Drive
Passenger Capacity4
Passenger Doors2
Body Style2dr Car
TransmissionEngine, 6.2L V8 SFI (426 hp [317.6 kW] @ 5900 rpm, 420 lb-ft of torque [567.0 N-m] @ 4600 rpm) (Requires (MN6) 6-speed manual transmission.)
1 Related Answer
charleshucke
Charles Huckeba
  • 1114 Answers
  • Posted on Jun 04, 2013
SOURCE: power seats not working
The first thing that I would recommend is to check the fuse box. Always start with the simplest thing first. If that isn't the issue, the next step would be to check under the seat and ensure that the wiring harness that powers the motor for the seat is connected. If for some reason that is not the issue, you need to check the connection to the power seat adjustment switch. If both of those are connected, you will then want to ensure that power is getting to both the switch and the motor. If you are getting power to the seat adjustment control and the motor the you may be looking at a faulty seat control switch, or a seat motor. Before you replace the motor you need to know that motors will "stick" and by gently tapping on the motor with a rubber mallet while activating the seat control will usually free the motor. If that doesn't work then you may need a new seat motor. I hope that you have found this information useful, thanks for using fixya!
2004 Land Rover Freelander TD4. Could an auto 2004 g/box be fitted to a 2013 Freelander TD4?
Wikipedia is usually the best place to work this out.
https://en.wikipedia.org/wiki/Land_Rover_Freelander
Although both TD 4, your 2004 is first generation.
  • 2.0-litre I4 BMW M47 diesel (2001-2006), badged as 'TD4'
But the 2013 is second generation and Ford based, but still TD4 or SD4
2.2 L Ford Duratorq 160 PS TD4
2.2 L Ford Duratorq 190 PS SD4 Transmission 6-speed Getrag M66EH50 manual
6-speed Aisin AWF21 automatic
https://www.google.com/search?q=2004+land+rover+freelander+td4+automatic+gearbox++in+a+2013+land+rover+freelander+td4
How do I reset tpms on 2013 ford explorer
There is no manual reset. If a light came on cuz a tire was low, just fill the tire and drive it. Sometimes it takes about 10mins of driving to turn off the light. It's automatic once the speed reaches a certain point
How dose the art 105 barrel work
The Mopar slant six engines - Allpar
www.allpar.com/slant6.html
The 1977 "Super Six" with a two-barrel Carter carb compensated for smog ... Heavy-duty slant six engines used in industrial and some truck/bus (perhaps fleet as well) ...You can retrofit the double roller chain and gears into car slant sixes, .... of way to have a twin exhaust system because, man, will that do wonders for a six.
Chevrolet straight-6 engine - Wikipedia, the free encyclopedia
https://en.wikipedia.org/wiki/Chevrolet_straight-6_engine
WikipediaMany popular cars and trucks, including the Chevrolet Camaro, Chevrolet Impala, ....resulting in an unequal and unbalanced work load between the six cylinders. ... in the 261 truck engine and used triple side draft, single barrel, Carter Model YH .... The '78 Camaro had 105 horsepower (78 kW) and 190 ft·lbf (260 N·m) of ...
Adjust the clutch linkage on a pontiac 2002 trans am 6 speed
How to adjust clutch??? 95 bird. - Fourth Generation Pontiac ...
www.firebirdnation.com/forums/.../65178-how-to-adjust-clutch-95-bird/
Dec 5, 2008 - posted in Fourth Generation Pontiac Firebird (1993 - 2002): I have ...Year: 2000; Make: Pontiac; Model: TRANS AM; Engine: 5.7L LS1; Transmission: MANUAL 6 SPEED T-56 ... Have you looked at your clutch master cylinder. Throttle is sticking after acceleration - Fourth Generation ...
Oct 7, 2011
1 Problem / Few questions - Fourth Generation Pontiac Firebird ...
Mar 26, 2010
Firebird Technical Service Bulletins - Fourth Generation Pontiac ...
Jul 5, 2006
TECH ARTICLE MASTER INDEX Look Here - Firebird Nation
Aug 18, 2004
More results from www.firebirdnation.com
How to Install Clutch 98-02 LS1 F-Body Part 1 of 2 - YouTube
? 12:31
www.youtube.com/watch?v=4BCHu2BwBMs
Apr 12, 2013 - Uploaded by MapleBoarder78
Part one of installing a new clutch on my 2000 Trans Am. Part 2 will include installation ... How to Master Cylinder Install and Drill Mod (LS1 F-Body) - Duration: ... 6:28. Removal and Servicing ofClutch Master Cylinder to Slave Cylinder ... LS1 98-02 Chevy Camaro Z28 SS Pontiac Firebird Trans Am F-Body ...
Want to boost the output on a 2013 regal gs
If something is wrong with the speed,then the transition needs repair/replacing.Most likely.
Im just asking what size the motor for a 1994 ford probe???
A dual-overhead-cam 4-cylinder engine powered base Probes in 1993, developing 115 horsepower. The GT coupe held a 164-horsepower V6, also of dual-overhead-cam configuration. Both engines are Mazda designs. No more turbocharged engines were available. A 5-speed manual transmission was standard; 4-speed overdrive automatic optional. Except for a slight horsepower/torque boost in 1995 for the 4-cylinder engine, and a mild V6 torque increase the year before, powertrains saw no change in this period.
Hope this helps (remember to rate this answer).
2answers
1988 V6 automatic camaro
You could Purchase A Hypertech Chip for the Computer. It will up the Horsepower Considerably and Cjange the Air Fuel Ratio for Better Mileage. Also, Get a K&N Air Filter. It will Increase the HP By at least 25% and will allow 50% Better Airflow. I would Start there. It is a LOT Easier to Beef up a V8 Than a V6 Though.
Top Chevrolet Experts
ZJ Limited
ZJ Limited
john h
Thomas Perkins
Thomas Perkins
Are you a Chevrolet Expert? Answer questions, earn points and help others
