Bosch MUM4420UC Compact Series Stand Mixer Logo
Posted on Jun 18, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Dishwasher will not drain at the end of cycle
Anonymous
Level 2:
  • Expert 109 Answers
  • Posted on Jun 18, 2009
Anonymous
Expert
Level 2:
Answers
109
Questions
Helped
55021
Points
298
Can you hear the drain pump humming or running?
If so, undo your drain hose from the drain or under your sink (if applicable) and look inside the spiggot (or small pipe) where you removed the drain hose from.
It may be blocked?
Repost if you need anymore help.
Thanks,
Adrian.
Is kitchen aid ice cream attachment dishwasher safe?
it should be dishwasher safe but just to make sure check the owner's manual it will have that information if it is not in there or you do not have the manual just call the store where you purchased it from
Washing Lower Portion Allowed?
I have a stick blender... not the same make, but I put the removable stem in the dishwasher without consequence.
1helpful
I ran 3 of my attachments through the dishwasher and the finish came off and they make your hands turn black when you touch them. Will they replace them for me? I can't believe that a product of this...
These attachments are not supposed to go through the dishwasher. They likely will not replace them, but you can purchase new ones at Reliable Parts:
http://www.reliableparts.com (USA)
http://www.reliableparts.ca (Canada)
Hobart am-12 manual and wiring
need to know if the motor on a hobart dishwasher model # am12 can be changed from 3 phase to single phase ? If so how ? I have no diagram on unit .
Jul 09, 2012 • Food Mixers
The paddle attachment has changed color, its kind of spotty. Is this normal? I have only used it 4 or 5 times....
If you have the burnished paddle (silver, not white) then it is not dishwasher safe. If you've run it through the dishwasher, it will discolor, but shouldn't affect the performance.
3helpful
Can't get the drive coupling off my Bosch Universal to replace it
I have had my Bosch Universal Mixer with the Blender and Food Processor Attachments since 2005, and I've loved it since the day I got it... that is, until the blender broke while my son was crushing ice to make slushies...
I figured out the "drive coupler" was stripped and needed replacing, but I couldn't figure out how to take apart the "blade assembly" which includes the "drive coupler" part...
My retailer, Pleasant Hill Grain, sent me the following email:
"I am not aware of any printed instructions for removing the old coupling and
replacing with the new. We recommend holding on to the blades with 1 hand and a
towel and using a needle nose pliers to unscrew the old coupling. You would put
the new coupling on in the same manner.
If these instructions do not work, I would suggest contacting the Service
Dept at Kitchen Resources in Utah. Their phone is 800-692-6724."
I still couldn't figure out how to take apart the blade assembly, so I did end up calling the distributor, Kitchen Resources...
Dave, the tech @ Kitchen Resources, answered my call on the first ring...
Once I explained my problem, he started giving me the same instructions Pleasant Hill Grain gave
me... I explained to him that holding the blades tightly wasn't working for me.
As it turned out, holding the blades did not secure the drive shaft because
the drive shaft was broken off INSIDE the blade assembly - which is why I could
not unscrew the old drive coupling part.
Dave's next question revealed the true issue at hand... my Blender Attachment has the blade assembly made of plastic - they switched to plastic
in 2005 because the metal assembly turned black in dishwashers.
Bosch just recently went back to using metal for this part - apparently the
plastic blade assembly didn't hold up.
Kitchen Resources - the U.S. Bosch Distributor - is sending me a new blade
assembly - no charge, he said it's covered under warranty. Woo Hoo!
Best of all, I hadn't yet purchased the replacement drive coupling part, because
I wanted to know how to go about replacing the part before ordering a new part.
With shipping this part would have been a $50+ repair - you have to love
customer service of that caliber!
[Aside: You really don't need to ever put this part in the dishwasher - wash
the inside with by putting hot water and perhaps a little dish detergent inside
the blender and turning it on - rinse the outside under the sink... no
dishwasher needed! ]
Looking for location of drain plug for m802
Look behind where the dough hook is near the pedestal,its a three quarter inch bolt.
2helpful
3answers
Black stuff wiping off beaters of kitchenaid mixer
If it's just the wire beater attachment, then it's possible it's oxidation from the metal/aluminum. Did you put it in the dishwasher? The manual says not to put the wire beater in the dishwasher. Hope that helps.
Mixer stopped turning when I was making bread
You probably have stripped the gear in the head section. It can be replaced, but I would consider this a advanced repair since you need to push steel pins out of the shafts to replace the gears. Use google to find a local repair shop, or fix it yourself if your mechanically inclined, parts are available online (and not that expensive).
Top Bosch Food Mixers Experts
Paul Bade
Grand Canyon Tech
Grand Canyon Tech
john h
Are you a Bosch Food Mixer Expert? Answer questions, earn points and help others
