Question about Bosch Food Mixers
Making High Pitch Noise, Sounds Strained
The Bosch I use is old (number 0710012101 on the bottom) and has been working like a champ until about a month ago. It has started to make a high pitched noise after the first minute or two of use and sounds strained. I thought this was due to the fact that when I make bread dough often makes its way in the bowl shaft and winds its way around the shaft (I take the bowl apart every time I use it to clean out the dough). However, I made cookies yesterday and no dough made its way into the bowl shaft but the high pitched noise once again started after a few minutes of use. The speed of the machine does not appear to be affected, there's just a horrible noise. I don't want to use the machine again until I figure out what could potentially be wrong...any ideas/suggestions?
Bill Boyd
    Top Expert:
  • Bosch Master
  • 53,814 Answers
The drive shaft bush is dry ( probably from dough getting up the shaft) have the unit serviced /repaired and properly lubricated using food grade lubricate
Posted on Mar 20, 2017
  • Julie Harrist
    Julie Harrist Sep 22, 2017
    where can you get the bosch serviced at?
  • Bill Boyd Sep 22, 2017
    service agents are listed on the bosch web site
5 Related Answers
Anonymous
  • 274 Answers
SOURCE: Grinding Noise
If it's metallic sound you are loosing teeth on a gear or two.  This is caused by lack of lubricant or simply fatigue of the material of the gears.  Don't use it, you can get metal flakes in your food.
Take it in to a repair shop and have it fixed.  The money spent is well worth it because if done correctly will last another 12 years.
Posted on Oct 23, 2007
Anonymous
  • 45 Answers
SOURCE: Kitcchen Aid mixer making a grinding noise
common problem. Worm gear & bracket #PS734273 about $36.
Posted on Nov 05, 2007
Anonymous
  • 25 Answers
SOURCE: kitchenaid mixer mades a high pitch squeak when mixing
Take it to a local repair shop and they should be able to fix it in no time.
Posted on Mar 26, 2008
Anonymous
  • 135 Answers
SOURCE: KitchenAid 600, Stand Mixer -
Hi. Stop using your mixer. If your mixer is still covered by warranty, call Kitchenaid Customer Service, they are very good with warranty repairs.
If your mixer is out of warranty, remove the silver band that surrounds the top of mixer. Remove the top cover. At the front of the mixer, locate the transmission housing which is now exposed. Examine this housing carefully for cracks. If you find cracks anywhere in this housing, you have found the under-engineered plastic transmission housing. Kitchenaid's replacement housing is made of metal. Your plastic housing has no business being in a mixer that is marketed as being able to mix bread dough. It cannot!
If you're confident that you can make the repairs yourself, go to the Kitchenaid website and download the parts drawings. Remove the Trans. housing, remove the worm gear shaft assembly which is driven by the motor.. Remove and save as much grease as necessary to thoroughly inspect the worm gear. Inspect the worm shaft bearings. Look for cracks, or missing pieces on the bearings. Look for crunched cogs on all gears. Be prepared to wait at least a month for your parts to arrive after you order them. The replacement grease should be Shell Darina 2, or Chevron FM ALC EP 2.
If you're not confident about repairing this yourself, call Kitchenaid and determine the nearest "approved" repair shop.
You may be able to pressure Kitchenaid to pay for the damaged parts in your mixer. They are still installing these plastic Trans. housing on new mixers. Insist on a metal cover when replacing. Apparently, Kitchenaid feels no shame in their manufacturing process, and will not issue a recall notice for these housings. They are substandard at best.
If you found this solution helpful, please rate it. Good luck! ricardok45.
Posted on Feb 13, 2009
Anonymous
  • 55 Answers
SOURCE: My mixer is making a grinding sound.
Its worth fixing but having someone who specializes in your product is the key, these machines are wonderful products and engineered great. I would say if your mechanically inclined jump on inside the machine and see whats going on, but if your NOT send unit to us USPS it's not that expensive plus you would only have to pay oneway, we will take care of the shipping from our side,,estimated cost $29.00-$49.00
Posted on Nov 24, 2009
Bosch sds drill wont turn off
Sounds like you have burnt something out. It likely won't last long. Probably the motor is gone.It may burn out when you put it to real work. Good luck.
Jan 19, 2016 | Bosch Food Mixers
Making a high pitch squeal
the unit needs service, i mean oiled and greased, it rubbing metal to metal and you are going to burn up the unit
Sep 17, 2015 | Robot Coupe R301 - Commercial Food...
Never used new bosch universal plus making bread started rattling sound
I do not know a lot about this machine. I am a DIY fix anything. It sounds like one of the mounting points on either the motor or the gearing gave way. Regardless it is new, send it back & have it fixed or replaced. Sorry, I know that is not what you wanted to hear, but is safest considering your investment.
Mar 10, 2014 | Bosch Universal Plus 6 Qt Mixer With 800W...
Kitchen Aid 550 Pro Mixer New Worm Gear and Worm Gear Follower Issue
It would be helpful to get the model number and serial number off of the bottom of the mixer. This will help determine if the gearing has changed at all.
Usually when a mixer is making a lot of noise after replacing the gears we can find a small nick or gouge in the gear. even the smallest damage can cause these mixers to make a lot of noise. Also if you have an older mixer there was a change in the worm gear from 53 teeth to 60 teeth on the gear. If your mixer originally took a 53 tooth gear, and you replaced it with the 60 tooth gear it will make a lot of noise like you are describing.
So first check your serial number, if the first 4 digits are after WL45 your mixer would have a 60 tooth gear, however if it is a WL44 or before you would have originally had a 53 tooth gear and this is what is causing the loud noise.
If your mixer is new enough that it took the 60 tooth gear, then take the mixer apart, clean and remove all gears, clean them off with wd-40 and inspect closely, even the smallest chip can cause a ton of noise.
If you have any questions, or you cannot find the problem feel free to contact us at The Mending Shed.
Thank you,
Colleen
Customer Service
MendingShed.com
800-339-9297
We Repair Anything Under the Moon!
Apr 04, 2013 | KitchenAid New Professional 5.5 QT...
KA 600 is making a clinking noise when mixing.
Tll,
It sounds like it could be an issue with the gear, the motor housing could have a crack in it. The problem could be much more involved as well. Put the unit on the slowest speed and see if you can stop the mixer from spinning. If it hiccups or stutters, that means you have a stripped gear. If you cannot stop the unit using your hand ON THE SLOWEST speed then there could be a problem with the motor housing or the motor itself not being held in place properly.
Apr 02, 2012 | KitchenAid ProLine 600 Stand Mixer
Old Bosch mixer on its last life?
Sounds like the motor is going. If it has a lifetime warranty (which I'm surprised to hear) it will be interesting to see if you can get it repaired. There are not many old parts around for the older models. I have one too that just needs the brown knob but can't find one anywhere! Good luck
Dec 08, 2009 | Bosch Food Mixers
Noisy, high pitched whirring MUM6622UC/01 Bosch Universal Mixer
My wife's bosch mixer had a similar problem but it was a very loud grating problem. I talked to the bosch dealer in Utah, sorry, I've forgotten which one-- the one that does the repair. This is typically what happens: the seal on the blender wears out, which results in fluids from the blender dripping into the motor, onto the upper motor bearing. So, the upper bearing corrodes and is what is causing the bearing failure and the loud noise (needed hearing protection to operate it). I was lamenting the cost and time it would take to ship the mixer both directions (not actually that much compared to the price of the mixer), and he said he would sell me the bearing and the bottom replacement part of the blender that was leaking. So, I did the repair myself, but it took awhile, and I had to build a puller for the bearing to get it off the shaft, modifying a harbor freight gear puller. But it now is back to new. So, it was a success for me, but i would recommend anyone who isn't very mechanical to just send it off to Utah (again, I forgot the place, I think they talk about the shop in one of the other posts), and you will have a better than new machine.
Nov 08, 2009 | Bosch 700 Watts MUM6622 Universal Series...
Kitchenaid mixer mades a high pitch squeak when mixing
Jan 28, 2008 | KitchenAid KSM90 Ultra Power Series Stand...
Bosch universal mixer
Sounds like the belt came off when you tried to mix the frosting while it was cold. Just too much of a load. It will have to be taken apart and the belt put back on.
May 29, 2007 | Bosch MUM6630 Universal Series Stand Mixer
Food Mixers Logo
455 people viewed this question
Top Bosch Food Mixers Experts
Marvin
Marvin
Andrew Taylor
Andrew Taylor
Are you a Bosch Food Mixer Expert? Answer questions, earn points and help others
