Just stopped working...the inside wall gets hot now not cold
If this is a stand alone icemaker. Is the unit running? If not check the icemaker ejector blades to make sure that its pointing at 12 oclock. If not then you need to take the cover off the icemaker and turn the smaller gear counter clockwise.(remove cover by gently prying on the inside corners and pull at the same time) Turning it counter clockwise will turn the ejector blade. Once you get it to 12 the plug the unit in and turn on. Compressor and fan should come on. If the unit is running then make sure the fan is operating. Yes then is the compressor on? Yes > then you have a sealed system problem. Let me know if you need further assistance.
