1995 Honda VF 750 C Magna Logo
A
Anonymous Posted on Jan 02, 2018
1995 VF750. The bike will start after i take off of the trickle charger. Idled for about 20 min then died and won't start. Put back on the trickle for a couple minutes and it started again. I think the bike is just running off of the battery power. What could have gone to cause this?
Adam Truesdale
Level 3:
Master:
  • Master 634 Answers
  • Posted on Jan 02, 2018
Adam Truesdale
Master
Level 3:
Master:
Answers
634
Questions
0
Helped
156512
Points
1822
It has either a generator or alternator style system. So ya your killing the battery and need to stop that till you fix the generator charging system. Check the fuses and wires for any breaks. May need a new stator or charging controller if the fuses are not the problem. May be even a bad ground wire.
5 Related Answers
Anonymous
  • 948 Answers
  • Posted on Jan 05, 2009
SOURCE: white smoke both pipes when started minute later gone away
White smoke indicates water in the combustion chamber. If the bike is still running okay I would keep an eye on the coolant level, make sure you're not losing any. Best guess is a blown headgasket. You can do a leakdown test or a compression test to check. If your headgasket is blown, two adjacent cylinders should show lower compression since pressure will be leaking from one to the other.
That's the kind of thing that probably won't run for long. Be sure and keep an eye on your oil level too, if you happen to be leaking coolant into the oil you can dilute the oil to the point it no longer lubricates very well.
Anonymous
  • 66 Answers
  • Posted on Feb 16, 2009
SOURCE: bike wont idle and power constantly dieing and recovering
check to see if you have gas in the oil from a carb leaking down which will cause the idle speed to drop when motor warms up.pick up idle run for awhile then plugs foul.like you said a carby problem.
emjem74
scott rimmer
  • 162 Answers
  • Posted on Feb 24, 2009
SOURCE: I have a Honda Rebel 250cc 1995 model.The battery
you will find with the age of the bike that the coil is probably caput. this camn be changed with a lot of brute force and ignorance. it is behind the crank housing and will only come off with a crank puller, this should solve your probs.
Anonymous
  • 126 Answers
  • Posted on Mar 13, 2009
SOURCE: Won,t stay cranked
try the bad gas route first by draining the tank and replacing it with fresh fuel.
if no joy, then i would focus on gummed up carbs. remove the carbs from the bike, then remove the float bowls from the carbs and take a look. my guess if the jets are clogged and/or lots of varnish on the float and bottom of the bowl. clean it all out including all of the orfices on the jets (main & pilot) and you should be a-ok.
Kolbrun Gunnarsdottir
  • 1228 Answers
  • Posted on Apr 02, 2012
SOURCE: 2006 Honda 750cc Shadow Aero starts with choke, runs for a minute, sputters and stalls. Won't start again for a couple of days, then starts right up. Electrical?
Hi there
I once had a wee car,whenever it got too much petrol inside itself it refused to go anywhere and had to rest for some time and you had to be very careful with the choke and the petrol so it did not swallow too much of it and need another rest.
kolbrun
1helpful
2answers
1995 VF750. The bike will start after i take off of the trickle charger. Idled for about 20 min then died and won't start. Put back on the trickle for a couple minutes and it started again. I think the...
You may just have a dead cell in the battery. The battery needs to be checked under load. Most shops will do a battery check for free. At least you can eliminate the battery itself as a culprit.
Why is my bike clicking and wont start?
make sure you got your terminals tight. then if so its still your battery not charged, just push it til you get jogging speed jump on put it in second pop the clutch it will start let it run about 20 to 30 mins should be enough charge built in your battery to restart it, if not your battery is bad even though its fairly new could be low on water inside it !
Jan 19, 2013 • Motorcycles
05 zzr 600 dies when driving and wont start back up
How long has the bike been sitting? Sounds like the carbs may be gummed up,and in need of a professional cleaning,and re-synchronizing.
I have a 1995 Honda cbr 600 f3 it won't start won't try an start the battery is fine so are the fuses I'm getting nothing no lights not even the ones that show your in neutral. It's really...
ORDER A CLYMER MANUAL FOR YOUR BIKE!!! Everything is easier to inspect with the fairings and accessory covers removed. While you are waiting for the manual, trickle charge your battery. Make sure your charger is a maintainer as well. It charges your battery and keeps it conditioned. Keep in mind, even if it's a new battery, they are not impervious to fault. When you get your manual, two or three days later, the battery should have a full charge as indicated by a green light(normally) on the trickle charger. Now, key your ignition on and get your multimeter. Read for battery voltage on the down side of your ignition switch.Then measure and note the draw from your battery as you hit the start switch. Open your manual and start reading through components like your rectifier, coils, main power fuse (probably a 30A)on your fuse box. Remember, a bad ground within your electrical system will report a failure to allow passable current to the components that need the juice. Look for corrosion or gunk on the contacts of your electrical components. Good luck, let me know how it works out.
1helpful
When i try start me bike it dose what to start when i push the button to start it go,s click click no more nose like it use too b4 i wash it be for me bike b4 it happen? it made a nose no nathing it go,s...
sounds like the battery doesn't have enough power.
Battery may be bad, or your charging system is bad.
If the bike was sitting for a while not being ridden (longer than 3 weeks) then the battery is probably dead.
go to a local powersports shop and ask them about a "trickle charger" this is what you plug the bike into when you park the bike for a long time like the winter. You can dfind a cheap charger for about $20. It has to be a trickle charger not a regular battery charger otherwise it could overcharge and the battery could explode or even catch fire. This will keep your battery from dieing everytime you park the bike for an extended period of time.
3answers
I just put my battery in the bike. I went to start it up, it powered up but when I went to start it up it clicked off.
The battery has to be fully charged on a trickle charger before putting it into the bike. The charging system in a bike is small compared to a car and does not keep the battery fully charged. Therefore, it is a good idea to put a trickle charger on it when it is idle.
1helpful
1993 Kawasaki 750R - Charging issue - Weird!!!
i know this sounds silly ,but when you bought the battery had it been activated,new batterys are critical in their first charge and you cannot use a standare type automotve charger,if bought dry the battery needs to have the acid filled ,left to sit for at least 2 hours prior to charging,once it has sat for the 2 hrs with the acid in,the new battery will need to be charged with a "cteck"or similar type charger for at least 13 hrs before it can be put into normal service,what happened with yours i think is that sure you gave it a charge but it has only recieved a "surface charge"and will be usable for a very short time,it may recover for a brief period and go again untill the surface charge dissipates,(or in other words ..runs out of charge)best thing you can do with the battery is take it to a auto electrician and have the battery cycled and conditioned,this is not expensive to do and will give you piece of mind,after conditioning the battery shouldngive excellent service,i have the battery in my goldwing coditioned about every 12 months and i have the same battery that was in the bike when i bought the bike 8 years ago and still no electrical or battery problems(costs about $25 to get it done)once a year but that beats $280 for a new one...hope this helps
1helpful
Replaced stator, brand new battery, died after 10k ride
sounds if regulator is not working or poor connections within charging circuit
Battery
they make a charger called a battery tender which keeps your battery topped at all times with a trickle charge. get one and your batteries won;t die.
Top Honda Experts
Arnie Burke
Arnie Burke
Sean Wright
Sean Wright
Mike Cairns
Mike Cairns
Are you a Honda Expert? Answer questions, earn points and help others
