Knobs broke of lever to lower toaster
SOURCE: Black & Decker T-1029 2-slice Toaster - lever broken
Main problem with these is crumbs, they get stuck between the 2 surfaces of the small electromagnet that keeps the lever down, consequently it does not stick anymore, try drop kicking it in the drection of the garbage can, this sort fright may just scare it into working again.
SOURCE: toaster control lever will not stay down
Unplug the toaster, turn upside down, and gently shake all crumbs out. There's been plenty of times when a stray raisin causes this problem!
Otherwise there may be a break in the element. In Australia toasters won't stay down unless the power is connected, and if there is a break in the element there won't be a continuous circuit.
SOURCE: just got this toaster, and
Is there any 'temperature' setting that needs to be adjusted higher, to make it stay?
What did the manual say about how to toast your first slice of bread?
It sounds like you might need to take it back, and get it replaced.
Tell us more--
Mack B
SOURCE: The lever doesn't stay down..for
is the power working at the receptacle which it is plugged into ??
try another receptacle, you may have a blown fuse or circuit breaker off
