20 Most Recent
Kenmore KTES8 Toaster Oven with Convection Cooking Questions & Answers
''start'' toast button no longer works on my kenmore toaster oven
Salton Model KTES8 toaster oven disassembly and repair
DISASSEMBLY
Remove two rear feet, each held by one screw.
Remove 8 screws holding back on.
Twist AC line cord grommet 90 degrees and slide off back.
Remove one screw on inside 2-1/4" from top on control side next to bell
(hard to see - hidden by wire insulation).
Remove 4 screws from bottom of wraparound case.
Push up case about 1/4" at the front to disengage locking tabs, then
gently slide back and spread sides of case, lift wraparound lip over the edge
it screws into, and then work the case towards the back until it easily
slides off.
Remove 3 knobs from right hand control panel (use flat blade of dinner
knife to gently pry on one side, then the other).
Remove screws that were hidden by knobs.
Remove two screws holding plastic control panel.
Remove 4 long screws and spacers holding circuit boards to plastic control
panel.
Remove plastic control panel.
Move circuit boards forward so they can be accessed. (be careful that after
disengaging the temperature control shaft from the circuit board that you
do not twist either the temperature control shaft or the knob shaft - they
will be reassembled by putting the shaft back into the slot.)
REPAIR
ZD1 Zener diode shorted - replace with 1N4742A (12V, 1W, NTE 142A, $0.99)
REASSEMBLY
Reverse ASSEMBLY instructions
How do i obtain a
http://www.managemylife.com/mmh/owner_manuals/314/KENMORE-Toaster-oven-L0709298
Short in electric wire you
Of course, the cord should be replaced. If you can do it yourself, then check with Sears or your local hardware store for a new cord. If you still have the manual then check in it for a service center if you need someone to fix it for you, or maybe Sears or hardware store could help.
Here is an web address that will give you a list of websites that sell oven parts if you can do it yourself and are still looking for a new cord.
netshoppers.com/search/index.php?phrase=oven+parts&uid=d5d00793c96dccbcaa9b5f3ca3d412cd&kuid=4c4a6ef184c15b7eeffee322a7d94921&src=7s
I AM JUST TRYING TO
i usually putthe temperature a bit lower since the food is nearer the heat source. and don't forget to check the food once in a while to see to it it doesn't get burned.
Hi , Gas range Kenmore #790.75658001.Self clean
Hi
Error F3 appears when there is something wrong with the keypad or the Electronic range control (ERC). Check that the keypad is firmly connected with the control board, then press Cancel, if error appears then you'll need to check the ERC. To resolve this issue disconnect the power to the range. Now gain access to the back of the clock (electronic range control or ERC). Now unplug the touch pad ribbon connector from the ERC, it would be a flat wire approx. 1 1/2" to 2" wide. Make sure that the cable is not cut and nothing is shorted on the keypad. Turn power back on to range and observe. If the error is still there then you would need to replace the board. Hope this helps...
Daniel
