Computers & Internet Logo
A
Anonymous Posted on Apr 01, 2014
Ad 72415 burner
SPECS
Can you get bluetooth or playstore on theese
if you are referring to 7 Multi Touch Tablet . Look at the specs page https://ematic.us/shop/egm002.html#Tech-Specs
It does not support Bluetooth and cannot be added.
It is hardware component and cannot be added from playstore.
Flame height on my 36 " 6 burner Viking Range Top
remove the knob, the center shaft is hollow, slide in a small blade screw driver to adjust the flame cheers
Unable to push Sony Optiarc AD-7585H to write at 1x
You're not "pushing" with 1x speed, that's the slowest speed at which a burner will burn at. You can change the write speed in the burning software settings.
Is this product compatible with Windows 7?
According to the specs at Buffalo-Technology it sure is Window 7 compatible. You can check the specs out here: http://www.buffalo-technology.com/files/products/DVSM-PN58U2V%20-DVD%20MultiDrive%20DS%20EN.pdf
I dont' know if i can burn dual layer dvds with the optiarc 7561s
Here is a link to the specifications of your burner.
Look in the Technical Specs and under supported media format they have listed "dl".
If anything you may have a firmware update available. (you can check on this site for any available ones).
Hope this helps.
http://www.sonynec-optiarc.com/products/hhid_dvdrw/ad7200.html
1helpful
1helpful
Can TS-H492B burn Dual Layer DVD's?
Specs from Dell Website
According to the Specs it should be able to burn DL+R, but not DL-R. Nero Express should work if it's a recent version that supports your model. An updated Nero version will have more support for different models of burners, but another great free software that can do almost as much as, if not more, than Nero Express is CD Burner XP, which is freeware and can be downloaded directly from their website CDBurnerXP
I can not burn a cd using windows, real player or music match, real player says it does not even detect a burner on my pc, where can i download drivers?
are your disks supported by the burner , note the burners specs say it only supports a cr/-rw disk maqking any other unrecognisable to the burner to write to.
My laptop freeze
what is your cpu, ram, dvd drive specs. it may be as simple as either adding more ram or upgrading the cpu, or updating the driver for your dvd burner
Top Sony Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
