Dell Inspiron N5030 Logo
d
duane tomic Posted on Mar 29, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Repeats windows is loading files
How to recover
Mike M
Level 3:
  • Dell Master 3,349 Answers
  • Posted on Mar 30, 2014
 Mike M
Dell Master
Level 3:
Answers
3349
Questions
0
Helped
686842
Points
16707
When laptop is first turned on press F8 repeatedly.
You will be in safe mode.
Choose safe without networking
Go to controlpanel/system/device manager
Fix the problems
How can I recover my cr700 when after going into recovery mode I have nothing on screen.the mouse works but blank screen.i get the win logo and loading windows files but nothing after that. I have tried...
If you have backed up your data (photos, documents, etc.) on an external hard drive, USB disk, DVD's.
If there is company data, or otherwise valuable data, this is better left to a professional! If you are able to cope with the possible loss of all your data, feel free to continue reading.
If you're unable to backup your data, you might try to do so with:
Easeus Data recovery Wizard
Data Recovery Wizard Free 8 6
After you have baked up your data. You could try to recover windows from the error by:
-Pressing F3 repeatedly when the unit is powered on.
-This will get you a menu to load Windows, or Windows recovery
-After this, select "Windows Sytem Recovery Options"
-Follow the on-screen options to try and fix the issue
-If this doesn't work, power on the laptop again and press F3
-load up the Windows option that you are given
!THIS WILL DELETE ALL YOUR PERSONAL DATA AND RESTORE THE COMPUTER TO FACTORY DEFAULTS!
-Select "MSI Recovery Manager"
-IF YOU ARE SURE IT'S OKAY TO LOSE ALL DATA: "OK" > "OK"
-IF F3 Doesn't work, either your recovery files are missing, or your hard disk is failing. If this is the case, you can read on at:
Reinstalling Windows when recovery fails MSI HQ User to User FAQ
Hope this helps!
Dell inspiration 1520 doesn't go past Windows Error window. My computer goes past the dell loading screen, then Windows Error. After I pick one (or go into f8 and pick system repair) then the screen goes...
Possible hard drive failure. You may have to reinstall the operating system and if that doesn't work then you have to get a new hard drive. The tech may or may not be able to recover your files from the damaged unit.
How do i reset a compaq cq45
I don't know if this helps...I've copied it from their website:
"Recovering your computer without recovery discsYou may not need recovery discs to recover the software on your computer. HP provides a recovery solution on a separate area of the hard drive. If the hard drive is still functional, you can still perform an HP system recovery from the hard drive as long as the recovery information has not been destroyed or corrupted.To do a software recovery from the hard drive, turn on the computer and repeatedly press the F11 key until "Windows is loading files..." displays on the screen. If your computer originally came with Windows XP or earlier, press F10 to enter recovery instead of F11."Regards,nicam49
I have a ASUS U52F Laptop I cannot load Windows 7. I am in ASUS Preload Wizard, I have 3 options to choose from 1) Recover Windows to First Partition Only. 2) Recover Windows to Entire HD. & 3) Recover...
You should remove your HDD Hardisk Drive and slave to other PC so that you can Backup your files Picture, Music Ect.
After backup all your files you may now proceed recovering your windows each either 1 or 2 option must be follow.
Best selection is Option 2 Recover Windows to Entire HD
1helpful
Recovery disc problems
the cd recovery you have need connect to hard disk by some files system when u change new hard miss these files so cannot do it. only u recover by use ghost from image
Wont load windows properly cant access recovery to recover factory settings
Hi...
You want to load your windows properly. You need a fresh copy of windows. Install the windows properly do not recover the existing windows maybe some files are missing. Make a new copy of windows.
Regards
PCmania
1helpful
My Toshiba L300 satellite pro wont load up
USE A BOOT CD AND RECOVER THE FILE AND MAKE SCAN VIRUS
rapidshare.com/files/51117041/ERD-2007.rar
IF YOU HAVE SATA DISK DISABILITATE SATA IN BIOS... TRY....
Data Recovery / Windows Start Up Problems
Hi
If you are just trying to recover the users files then you can use the following link to help.
http://www.mypchealth.co.uk/GuideRecovery.php
1helpful
3answers
File system currupted/hard disk problem
Yess it is just email me at : [email protected] and i will send you instructions how to recover data...
Beni
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
