Power Acoustik PTID-4003TV Car Video Player Logo
Charles Shoots Posted on Mar 28, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to install
Where all the rca jacks go
cals-studio
Level 2:
Scholar:
  • Expert 128 Answers
  • Posted on Mar 28, 2014
cals-studio
Expert
Level 2:
Scholar:
Answers
128
Questions
Helped
37375
Points
307
The rca jacks go to amplifiers and additional screens if you don't have those you don't need to use them .
How to add external rca jacks to the output
To connect your audio receiver to your Proview 3200 flat screen TV, you can use RCA cables. Here are the steps:
Locate the RCA jacks on your TV and audio receiver. One jack is white, and the other is red.
Plug the white RCA cable into the white jack on the TV and the red RCA cable into the red jack. Reversing them will cause the stereo signal from the TV to be incorrect.
Take the other end of the RCA cables and plug the white and red ends into an available RCA input on the back of your audio receiver.
If your TV doesn't have RCA jacks, you can use a digital-to-analog audio converter to connect your TV to a 5.1 audio system that has only RCA inputs 1. You can follow these steps:
Unbox the digital-to-analog converter.
Connect the optical cable to the converter.
Connect the RCA cable to the converter.
Connect the other end of the RCA cable to an available corresponding analog audio input on your audio receiver
Is it possible to install aux 3,5 mm plugg?
Probably not, but you can buy a 3.5 mm.-to-RCA adapter cable to hook up a device with RCA (L/R) AUDIO OUT jacks (and no 3.5 mm. headphone jacks) to your Harman Kardon speakers which, I assume, have only 3.5 mm. LINE/AUX IN jacks (1 or 2).
I want to use the Amp inputs on the rear panel. I require the jumper plugs. I have lost these as I have been using a mixer up to now. Can you help locate some please??
If you're trying you connect the LINE OUTPUT RCA jacks to the PREAMP INPUT RCA jacks, but lost the jumpers that used to connect the two, you can simply buy the shortest RCA patch cables you can find, and plug them in Left IN to Left OUT, Right IN to Right OUT, etc. The jumpers look like the two installed between RCA jacks below.
Do this for as many jumpers that you are missing.
We have RCA executive series 4 line telephones. Is there a juction box that we can install to make this system work?
The RCA 4 line phone uses 2 standard telehpone jacks. Line
1&2 on the first jack and lines 3&4 on the second jack.
Is there a way to hook up a bass system to a factory radio that dont have rca jacks
local radio shops can tap into the preamps and install the RCA jacks, seen this done many times, contact a car audio sales and installation center for details
I have a 2007 ultra with harmon kardon stereo i have a sirrius sat wired in and plugged into the deck poor volume. does this deck have rca jacks to plug in amp
No RCA jacks stock, But Iron Cross Audio had a custom program to install RCA preamp outputs into that unit. (www.ironcrossaudio.com)
Sylvania vcr/dvd installation
!st) The antenna INPUT::RF (black wire usually from "cable TV", "Dish TV", even ANTENNA air wave reception,etc.) into INPUT of VCR\DVD, OUTPUT of VCR\DVD to TV RF input.
2nd) If you have INPUT\OUTPUT to what are called " RCA " jacks on your TV, on the front or on the back, then any & all output jacks from VCR\DVD goes to INPUT\OUTPUT of the TV.
In other words:: output of audio on VHS\DVD to input of audio on TV( RCA jacks). Output of video on VHS\DVD to input of video (RCA jacks)
Hope this helps
2answers
Subwoofer instalation
Even if your JVC doesn't have outputs for a subwoofer you can hook it up with the a speaker wire to RCA converter. You just spice your rear speaker wires to this device then connect RCA's to your amp. I've used them before... works great. http://cgi.ebay.com/ebaymotors/Speaker-to-RCA-Line-Level-Converter-Adjustable-High-Low_W0QQitemZ130143832174QQihZ003QQcategoryZ38636QQcmdZViewItem
Top Power Acoustik Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
ZJ Limited
ZJ Limited
Are you a Power Acoustik Car Audio and Video Expert? Answer questions, earn points and help others
