Sorry to here about your problem with the orange flashing light.
1st. You really are not giving enough information to
identify your problem.
2nd. If your battery is charging when unit is turned off and you can see a blue charging light on the front left panel,
that's good but should only charge for 1 or 1 1/2 hrs. max.
3rd. If your charger is getting to hot to hold while attempting to charge the
battery, you may have a bad battery.
4th. If the orange light
disappears after removing the battery and replacing it with a known good battery, its the battery.
This unit is an HP and HP has a recall on many battey's. ( I have worked on al least 25 HP Laptops and in two years have not found a battery to return under recall ) Thanks, HP !!!
All and All, it sounds like the battery is
NFG.
Drop me a email or reply here as to what you have found.
John Ray
[email protected]
