Craftsman NEXTEC 11812 12 Volt Lithium-Ion 3/8-Inch Reversible Drill/Driver Logo
Posted on Feb 05, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I pull the trigger and my LED light flashes but the motor doesn't engage.
Anonymous
Level 1:
  • Contributor 3 Answers
  • Posted on Jan 10, 2013
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
20597
Points
Bret Eliezer
Level 1:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 2 Answers
  • Posted on Jul 28, 2022
Bret Eliezer
Contributor
Level 1:
Welcome Back:
Answers
Questions
0
Helped
24556
Points
7
Did it get wet? My wife's did that after being left outside
chris jakes
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jul 03, 2014
chris jakes
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
20531
Points
Bump reactive this problem
woobie dog
Level 3:
President:
  • Master 1,273 Answers
  • Posted on Feb 05, 2011
woobie dog
Master
Level 3:
President:
Answers
1273
Questions
Helped
592872
Points
4197
Move your switches and then positively set them to a position. Usually, when a switch is in between settings, it will not operate correctly. Give it a try.
--W/D--
Dear everybody! I need a little help. I have a Paslode Im90i type nail gun. Last week on my nailer led going to flashing yellow, ok it need a service, i made it. After that i tried to reset the gun, but...
The reason the light isn't green is because your battery is not fully charged - if you have charged it, the battery may be at the end of its life.
The reason it is not firing unless you depress the nose several times is because your fuel cell is spent - check the expiration date on the bottom of the fuel cell.
Ryobi p251 hammer drill doesn’t run when trigger pulled and led flashes 4times
This is caused by a factory defect return the drill to a dealer.
My milwaukee sawzall won't start. It click'S when I pull the trigger,and led light above the blade starts to pulse in increments of three flashes. Any ideas on what would cause this??
try to switch a full battery look the carbon brushes try to turn on the motor to look its has no point with to heavy resist maybe a defect in the mechanism or electrical problem armature carbon brushes
1helpful
2answers
Nail gun will not fire green light on gas ok after drop on congrete floor
A quick diagnostic check. First remove gas cell press nose against solid surface to dispose of any gas that may be in chamber.
1. Insert battery - LED should flash.
2. Press nose against solid surface - LED should be lit permanently (if still flashing possible fault moulded circuit board or fan motor micro switch lever, if flashing red green high possibility motor fault). Listen to hear fan running if not heard fan blade may have fallen off motor.
3. While still pressed against solid surface press trigger and watch LED - LED should blink off then light again (may flash red on guns newer than 2006) If does not blink fault either Spark unit (controller) or moulded circuit board trigger micro switch. To test for LED blink again release pressure on nose then press again. The blink indicates that a spark has been sent to the spark plug.
4. If 1 to 3 are OK problem most likely gas related or leak in seals. Ensure driver blade not still forward a possible fault of sticking forward after being dropped is nose slightly bent this traps the driver blade when first fired and does not return. (jammed nail gives a similar fault.) If nose is the fault it will require a new sleeve.
The moulded circuit board is normally cheapest then spark unit and sleeve roughly about same price the motor is most expensive.
Hope this has been some help to you.
Shoprider power chair won't move and 8 Battery LED Lights are flashing
Code 8: Controller problem. Also, check to see if your gearbox levers are engaged - if you can roll the chair by hand the gearbox is not engaging the motors.
The does not completely close and one light is green and one yellow i see no disruption. then it opens up again what can i do?
Color of lights doesn't matter. If the main light flashes 10 times when the door reverses it is a door sensor problem. Make sure they are not flickering ever so slightly. Tweak them a little. On the rear of the motor unit there is a small LED. Check to see if it is flashing a code. It will flash a number of times, pause and then repeat. Near where that LED Is you will find the down force adjustment. Increase it about 1/4 turn and try. If the LED is flashing code 5 you most likely have a bad RPM sensor board which is a small printed circuit board just in front of the motor.
2helpful
2answers
I just recently purchased a 1997 BMW 328i. I found a red strap protruding from the underside of the rear seat and pulled it. After some research, I realized it's the release arm for two cables that...
There are 2 motors that have to be put back in place one for the top & one for the top cover... If you have reconnected both & still have problems you can resynchronize the top by rolling down all windows, hold the top button in the close position before turning the key, turn the key on and wait for the windows to close & the red light to stop flashing.
If this doesn't work pull the release arm, manually lower the top, (to get into trunk the passenger side of the top cover needs weight on it to engage micro-switch to release trunk lock)
reconnect motors, hold the top button in the close position before turning the key, turn the key on and wait for the windows to close & the red light to stop flashing.
1helpful
Paslode framing nailer 1998 yr. model when engaged wont fire
you have spark and cleaned tool correct, but fan won't turn that freely, if so the fan motor is bad, it should come on when you pull the trigger or move the roller lever for the safety. The fan is about 80.00 Let me know if I missed something and how did you check the spark?
Top Craftsman Drills Experts
Sean Wright
Sean Wright
Thomas Perkins
Thomas Perkins
john h
Are you a Craftsman Drill Expert? Answer questions, earn points and help others
